FADEC Posted September 5, 2023 Report Posted September 5, 2023 Looking for Mooney Part # 930023-009 the panel mounted Electric Trim Switch for a 1978 J. The Klixon part number is 20TC2-BG-5. I am open to an alternate solution as well. Thanks Andy
N201MKTurbo Posted September 5, 2023 Report Posted September 5, 2023 13 minutes ago, FADEC said: Looking for Mooney Part # 930023-009 the panel mounted Electric Trim Switch for a 1978 J. The Klixon part number is 20TC2-BG-5. I am open to an alternate solution as well. Thanks Andy https://www.airpowerinc.com/20tc2-bg5
Aerodon Posted September 5, 2023 Report Posted September 5, 2023 Andy, I'm prettier sure I have a spare one, will go look in the hangar tomorrow. Aerodon
FADEC Posted September 5, 2023 Author Report Posted September 5, 2023 Thanks @N201MKTurbo ! @Aerodon if you have one that would be great!
ArtVandelay Posted September 5, 2023 Report Posted September 5, 2023 Looking for Mooney Part # 930023-009 the panel mounted Electric Trim Switch for a 1978 J. The Klixon part number is 20TC2-BG-5. I am open to an alternate solution as well. Thanks AndyI have one, but part number is -3? This was also off a 78 J.
FADEC Posted September 5, 2023 Author Report Posted September 5, 2023 @ArtVandelay Don’t think that will work, thing the last number is the amperage. Think -3 is 3 amps and the -5 is 5 amps.
ArtVandelay Posted September 5, 2023 Report Posted September 5, 2023 [mention=11849]ArtVandelay[/mention] Don’t think that will work, thing the last number is the amperage. Think -3 is 3 amps and the -5 is 5 amps.I thought the 20 is the amperage, the -# is the text., but you’re correct.
Fly Boomer Posted September 5, 2023 Report Posted September 5, 2023 15 hours ago, FADEC said: Looking for Mooney Part # 930023-009 the panel mounted Electric Trim Switch for a 1978 J. The Klixon part number is 20TC2-BG-5. I am open to an alternate solution as well. Thanks Andy If you don't want to go with new, these people usually guarantee their stuff to work: https://baspartsales.com/20tc2-bg-5-alt-930023-009-klixon-elevator-trim-rocker-switch/
201Mooniac Posted September 5, 2023 Report Posted September 5, 2023 I'm pretty sure I have one from my 1980 M20J. I can check in the hangar next time I go.
FADEC Posted September 5, 2023 Author Report Posted September 5, 2023 @Fly Boomer that one is sold out, I have called a bunch of salvage yards after reading your post they will be getting back to me in the next couple of days. @201Mooniac thanks for looking appreciate it! Andy
Fly Boomer Posted September 6, 2023 Report Posted September 6, 2023 4 hours ago, FADEC said: @Fly Boomer that one is sold out, I have called a bunch of salvage yards after reading your post they will be getting back to me in the next couple of days. @201Mooniac thanks for looking appreciate it! Andy Sorry I didn't see the "out of stock".
mhrivnak Posted September 6, 2023 Report Posted September 6, 2023 I have the ETA version out of a 1990 M20J. It's marked "41-10-P10" and "5A AC250V" on the back. Let me know if that would work for you. https://photos.app.goo.gl/u9kBTwbUz8Si4Uqy8
mooneyflyfast Posted September 6, 2023 Report Posted September 6, 2023 That’s a switch with a built in 5 amp breaker if I’m not mistaken. You could probably replace it with a toggle switch and a 5 amp fuse
A64Pilot Posted September 6, 2023 Report Posted September 6, 2023 3 hours ago, mooneyflyfast said: That’s a switch with a built in 5 amp breaker if I’m not mistaken. You could probably replace it with a toggle switch and a 5 amp fuse If your going to a toggle switch I’d go with a switch breaker, I hate fuses https://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr2.php 1
ArtVandelay Posted September 6, 2023 Report Posted September 6, 2023 [mention=11849]ArtVandelay[/mention] Don’t think that will work, thing the last number is the amperage. Think -3 is 3 amps and the -5 is 5 amps.Interesting mine should have been the same as yours, which make me think one of us had their switch replaced at some point, I wonder if there is a way to tell which switch corresponds to which Mooney part number?
FADEC Posted September 7, 2023 Author Report Posted September 7, 2023 @ArtVandelay I think the Mooney part number is the switch part number I listed. But I’m very new at this and probably wrong. That switch is for the electric trim with the KFC200 AP system. I bought a switch from @Aerodon, hope it works looks a little different. The mechanic at my field said getting it to fit on the bus bar will be the problem. @A64Pilot if the switch I have coming doesn’t work I’ll see if my mechanic will give that a try. andy
Aerodon Posted September 7, 2023 Report Posted September 7, 2023 4 minutes ago, FADEC said: @ArtVandelay I think the Mooney part number is the switch part number I listed. But I’m very new at this and probably wrong. That switch is for the electric trim with the KFC200 AP system. I bought a switch from @Aerodon, hope it works looks a little different. The mechanic at my field said getting it to fit on the bus bar will be the problem. @A64Pilot if the switch I have coming doesn’t work I’ll see if my mechanic will give that a try. andy The Trim switch is not on the busbar, so you should be OK. Aerodon
201Mooniac Posted September 7, 2023 Report Posted September 7, 2023 On 9/4/2023 at 8:37 PM, FADEC said: Looking for Mooney Part # 930023-009 the panel mounted Electric Trim Switch for a 1978 J. The Klixon part number is 20TC2-BG-5. I am open to an alternate solution as well. Thanks Andy @FADEC I have the switch you are looking for. It came out of my 1980 M20J. It shows it as a -5 part number.
ArtVandelay Posted September 7, 2023 Report Posted September 7, 2023 The Trim switch is not on the busbar, so you should be OK. Aerodon It’s been a while, but I thought the 12v+ was a bus bar (strip of copper, all the terminals should align nicely if it’s the same type), he’s not referring to the main bus bar.
Aerodon Posted September 7, 2023 Report Posted September 7, 2023 5 hours ago, ArtVandelay said: It’s been a while, but I thought the 12v+ was a bus bar (strip of copper, all the terminals should align nicely if it’s the same type), he’s not referring to the main bus bar. I'm sure it varies by year. Some switches are on the busbar that is fed any a 70A Aux CB. The Primer button is not on this busbar and is protected by an inline fuse off this busbar. The Trim on the KFC150/200 autopilot is completely separate. You are probably correct, a trim switch that is not part of an autopilot is probably on the busbar. Aerodon
