aviatoreb Posted August 9, 2023 Report Posted August 9, 2023 On 8/6/2023 at 5:12 PM, hubcap said: I keep seeing this description used…so what is your definition? Icing? Low ceilings? Convection? Sometimes you bump into a hard cloud and bounce off. Thats a hard cloud sometimes called hard IFR. 2 2
M20F Posted August 9, 2023 Report Posted August 9, 2023 11 minutes ago, aviatoreb said: Sometimes you bump into a hard cloud and bounce off. Thats a hard cloud sometimes called hard IFR. Sounds like a math problem.
aviatoreb Posted August 9, 2023 Report Posted August 9, 2023 9 hours ago, M20F said: Sounds like a math problem. Seems more like a physics problem - I was describing hard billiards. :-)
Pinecone Posted August 9, 2023 Report Posted August 9, 2023 A number of people have bumped into hard clouds. Commonly call cumulogranite clouds. It is normally a VERY bad thing. 1 1
Jerry 5TJ Posted August 9, 2023 Report Posted August 9, 2023 31 minutes ago, Pinecone said: A number of people have bumped into hard clouds. Commonly call cumulogranite clouds. It is normally a VERY bad thing. Might be better described as “abrupt termination of IFR flight.” 2 1
Stetson20 Posted August 14, 2023 Report Posted August 14, 2023 My personal "hard IFR" was last month trying to reposition my plane from KGRR to K9D9. Smoke from the Canadian fires had visibility less than a mile. As I was on the ground, I could look up and it seemed a lot like a thin fog layer. I planned to take off with an IFR clearance, and cancel once above the "layer." Nope. It was IMC the whole way (all of about 30 miles) and I was preparing to fly the GPS approach in to 9D9 as they vectored me right over the top of the field. I could see straight down from 2000 ft (min vectoring altitude) so I canceled, and entered the vfr pattern from there. But I will say that the smoke was the most deceiving conditions I'd ever been in. I'll have a better plan next time. Most likely wait it out. My 2 cents... 3
Bartman Posted August 22, 2023 Report Posted August 22, 2023 A few years ago I used to fly IFR quite a bit and got comfortable with extended times in IMC enroute and all the way to minimums, as long as it was not a convective environment. One time ceilings were low and since the layer was only a few hundred feet thick and clear on top, I decided to take off. I was IMC at about 20-30 feet, and I was not prepared. That was hard IFR, and I will never do that again. 3
