JoeM Posted August 3, 2023 Report Posted August 3, 2023 This antenna is below the belly, with 2 thick blue wires running to behind the panel where they are snipped off. What is it?
kortopates Posted August 3, 2023 Report Posted August 3, 2023 Looks like there is a storm scope antenna further forward under the belly.
EricJ Posted August 3, 2023 Report Posted August 3, 2023 ADF "boat" antenna. FWIW, the contemporary use seems to be as a wear block to protect the belly in the event of a gear-up landing. I've seen a couple examples where that worked really well. 2 3
OR75 Posted August 4, 2023 Report Posted August 4, 2023 ADF antenna. not that difficult to remove if you want to loose a few pounds and clutter
0TreeLemur Posted August 4, 2023 Report Posted August 4, 2023 8 hours ago, OR75 said: ADF antenna. not that difficult to remove if you want to loose a few pounds and clutter They are surprisingly light. 1.4-2.4 lb depending on the model. I left mine on as a wear block as suggested by @EricJ, just in case
