Apparently my GTN750 decided it doesn’t want to display my Jeppesen charts anymore. It’s a feature I never used, but now that I don’t have it I want it back. Anyone run into this before? Thought I would check before I spend a long time on hold with Garmin only to have them tell me to talk to my avionics shop (which doesn’t often have an answer). Maybe @TrekLawler is around? The screen says “Disabled 10-NOV-22” but doesn’t say how or why.
You said "...It’s a feature I never used..." so did you keep the Chart Data current, or only the Nav Data up to date?
If the Chart Data is not current, I would expect the GTN to not show you the old chart.
Different unit, but my G3X shows me my expired charts. I feel like a 750 should as well.
The charts are current. JDM updates everything and I double check. It just won’t display them.
