You'll need to convert your wiring over from the the Terra to the ACK (not sure if they are interachangeable) and then run your static lines to the new encoder. Should be relatively straight forward. Give me a bit and I'll try to find manuals to see exactly what you need.
I'll PM you
Edited by AnAngryGoose
