On my last flight, EGT on cylinder #3 was feeling footloose apparently. It wandered up into the the normal range at times but mostly went up and down in a range 500-800 degrees below the normal. I tried a couple of mixture settings but it was still dancing to a different tune. Anyone experience this? Not really that concerned about it but would like to know if it looks like a new probe is needed or if something else is afoot. CHT remained normal.
Probably needs new probe, but check/tighten the connection to the harness first, maybe put a little stabilant 22 on the connection - this worked for me once when I thought the probe was toast.  EGT probes go bad commonly.
I've had this happen numerous times in the dozen-ish years we've had an engine monitor.  Sometimes it was a bad probe, but other times it was just a broken thermocouple wire.  Mine happens to be an Electronics International system, and EI has changed the connectors they use for thermocouple wires a couple of times.  They won't admit it's due to the older connectors being prone to wire breaks at the crimp, but that's almost certainly the reason.
Defiantly check the connections. This happened to me just after installation and it was a loose connection. Zip Tie, Zip Tie, Zip Tie
I'm a big fan of Grip Lock Zip Ties, check them out.
