FlyWalt Posted September 10, 2022 Report Posted September 10, 2022 Hi Guys, I am finding some leaks at my valve covers and am about to tighten them up. Do we have to torque these? And if so, what would be the spec. This is a TSIO-360LB. Thank you in advance, Walt
smwash02 Posted September 10, 2022 Report Posted September 10, 2022 If you have the RealGaskets (silicon) you need to follow their specs closely. Over tightening will cause a leak. If you don't have them, I suggest them. Reusable and have done well for me. 4
PT20J Posted September 10, 2022 Report Posted September 10, 2022 5 minutes ago, smwash02 said: If you have the RealGaskets (silicon) you need to follow their specs closely. Over tightening will cause a leak. If you don't have them, I suggest them. Reusable and have done well for me. SL L272A Silicone Rocker Box Cover Gaskets.pdf 3 1
kortopates Posted September 10, 2022 Report Posted September 10, 2022 Following the spec ensures they remain leak free, as well as re-usable for many years. 2
Fly Boomer Posted September 10, 2022 Report Posted September 10, 2022 40 minutes ago, FlyWalt said: Hi Guys, I am finding some leaks at my valve covers and am about to tighten them up. Do we have to torque these? And if so, what would be the spec. This is a TSIO-360LB. Thank you in advance, Walt Other similar engines suggest 55-65 inch-pounds. That is probably not correct for silicone gaskets. EDIT: I just read the SL provided by Skip, and I see that the torques are somewhat less than the Continental reference I found, but still illustrate that silicone gaskets require less torque.
EricJ Posted September 10, 2022 Report Posted September 10, 2022 1 minute ago, Fly Boomer said: Other similar engines suggest 55-65 inch-pounds. That is probably not correct for silicone gaskets. The cork gaskets require higher torques. The Lycoming service letter points out this distinction.
jetdriven Posted September 10, 2022 Report Posted September 10, 2022 Continental has you torque the silicone valve cover gaskets to a lower number, and have you put blue Loctite on the screws when you install them. The last time I torqued a Lycoming valve cover with a torque wrench, three of them fell out off of one valve cover in the span of an hour flight.
Guest Posted September 11, 2022 Report Posted September 11, 2022 8 hours ago, FlyWalt said: Hi Guys, I am finding some leaks at my valve covers and am about to tighten them up. Do we have to torque these? And if so, what would be the spec. This is a TSIO-360LB. Thank you in advance, Walt Yes you need to torque these, with a new lock washer as well. The value listed assuming factory gasket not aftermarket.
FlyWalt Posted September 12, 2022 Author Report Posted September 12, 2022 Clarence, A Sincere Thank you to one of the great mechanical minds on MooneySpace. We greatly appreciate it. Walt 1
MisfitSELF Posted September 12, 2022 Report Posted September 12, 2022 The Lycoming SSP-1776-5 shows 35 in-lbs for silicon gaskets. Not sure if this applies to your engine. Lesson I've personally learned. If you get the gaskets that are a buck or two cheaper from aircraft spruce (the one that don't say if they are PMA'ed) then the bolt holes will be too big and it will leak oil through the bolt holes. Make sure you get the ones the seal up against the bolts. In other words, the gasket bolt hole diameters should be snug against the bolt as you screw them in. But don't over torque! Bruce
carusoam Posted September 13, 2022 Report Posted September 13, 2022 17 hours ago, FlyWalt said: Clarence, A Sincere Thank you to one of the great mechanical minds on MooneySpace. We greatly appreciate it. Walt Great thank you note Walt! @M20Doc probably came by already… Go MS! Best regards, -a-
jetdriven Posted September 13, 2022 Report Posted September 13, 2022 On 9/10/2022 at 8:17 PM, M20Doc said: Yes you need to torque these, with a new lock washer as well. The value listed assuming factory gasket not aftermarket. I think the on Lycoming valve cover screws, the lock washer is integral to the screw. 1
Guest Posted September 13, 2022 Report Posted September 13, 2022 2 hours ago, jetdriven said: I think the on Lycoming valve cover screws, the lock washer is integral to the screw. Correct on a Lycoming and they are seldom replaced other than at overhaul. On a Continental the lock washer so readily replaced.
Will.iam Posted December 6, 2022 Report Posted December 6, 2022 Which is better for low torque values like what is required for silicone gaskets for the rocker covers, lock washers or star washers? I ask as i noticed i have lock washers on all my covers except the one cover that is next to the oil cooler it has a star washer. Shouldn’t they all be the same one way or the other?
kortopates Posted December 6, 2022 Report Posted December 6, 2022 My recollection is split washers.But the TCM IPC is available online for free. So I’d encourage anyone with a parts question to look it up online.M-O and other TCM maintenance manual’s unfortunately aren’t free nor online; except for perhaps an out of date version.Sent from my iPhone using Tapatalk
Guest Posted December 6, 2022 Report Posted December 6, 2022 10 hours ago, Will.iam said: Which is better for low torque values like what is required for silicone gaskets for the rocker covers, lock washers or star washers? I ask as i noticed i have lock washers on all my covers except the one cover that is next to the oil cooler it has a star washer. Shouldn’t they all be the same one way or the other? Generally, Lycoming engines use internal star lock washers, MS35333, while Continental engines use split lock washers use MS35338.
Fly Boomer Posted December 7, 2022 Report Posted December 7, 2022 56 minutes ago, M20Doc said: Continental engines use split lock washers use MS35338. 18-8 or 316?
Yetti Posted December 7, 2022 Report Posted December 7, 2022 I torqued my silicone gaskets to spec. After carefully cleaning the old ones off. Then the grumpy IA came up and put a screw driver on them. So I had to glare at him. Still have not leaked. The drain tubes are another thing.
Guest Posted December 7, 2022 Report Posted December 7, 2022 49 minutes ago, Fly Boomer said: 18-8 or 316? Cadmium plated carbon steel
MikeOH Posted December 7, 2022 Report Posted December 7, 2022 Per the Lycoming parts manual for the IO-360 the valve cover P/N: STD-1925 comes with external star washer:
