PeteMc Posted June 25, 2022 Report Posted June 25, 2022 (edited) Went up to 6B6 today for an AOPA event. Restaurant it open and the fuel is $6.69 (less if you have an Acct with them). There going to be having more BBQ and also talking about live music. So if you're in the area, give it a thought. Edited June 25, 2022 by PeteMc
Marauder Posted June 26, 2022 Report Posted June 26, 2022 Went up to 6B6 today for an AOPA event. Restaurant it open and the fuel is $6.69 (less if you have an Acct with them). There going to be having more BBQ and also talking about live music. So if you're in the area, give it a thought.But watch out for that drainage ditch!Sent from my iPhone using Tapatalk Pro
PeteMc Posted June 26, 2022 Author Report Posted June 26, 2022 8 hours ago, Marauder said: But watch out for that drainage ditch! That big hole with the drain at the bottom on the approach end of 12 (in the middle of the tie-downs)? Or is there a different one?
Marauder Posted June 26, 2022 Report Posted June 26, 2022 That big hole with the drain at the bottom on the approach end of 12 (in the middle of the tie-downs)? Or is there a different one? It’s on the taxiway. Bob Belville found it with his prop. Sent from my iPhone using Tapatalk Pro
Hank Posted June 26, 2022 Report Posted June 26, 2022 2 hours ago, Marauder said: It’s on the taxiway. Bob Belville found it with his prop. I thought that was fixed after Bob hit it.
carusoam Posted June 26, 2022 Report Posted June 26, 2022 Early days of Bob’s forever plane experience… -a-
PeteMc Posted June 26, 2022 Author Report Posted June 26, 2022 3 hours ago, Marauder said: It’s on the taxiway. Bob Belville found it with his prop. North or south end? I was only on the south end of the taxiway. Landed 21, after lunch taxied up for fuel and by then the winds had shifted, so departed 03. Never used the northern half of the taxiway.
