Dick Denenny Posted February 28, 2022 Report Posted February 28, 2022 Anybody have this happen to them Quote
N201MKTurbo Posted February 28, 2022 Report Posted February 28, 2022 19 minutes ago, Dick Denenny said: Anybody have this happen to them Yes. Took about 5 min to make a new one. Took a lot longer to paint it. Quote
carusoam Posted March 2, 2022 Report Posted March 2, 2022 Don’t forget the bent leading edge and rubber spacers… The sheet metal screws are supposed to grip into a Tinnerman on the inside… Tinnermans probably got old, and stopped gripping… check the other side to see if they are there…. IIRC… PP thoughts only, not a mechanic… Best regards, -a- 1 Quote
N201MKTurbo Posted March 2, 2022 Report Posted March 2, 2022 8 hours ago, carusoam said: Don’t forget the bent leading edge and rubber spacers… The sheet metal screws are supposed to grip into a Tinnerman on the inside… Tinnermans probably got old, and stopped gripping… check the other side to see if they are there…. IIRC… PP thoughts only, not a mechanic… Best regards, -a- I cut the leading edge about 1” too long, then bent it in the brake and then trimmed it to the correct length in the shear. I then filed and sanded the leading edge so it wouldn’t scrape the Paint excessively. 2 Quote
KB4 Posted March 2, 2022 Report Posted March 2, 2022 Had similar, top screw popped out and panel sheared and bent between top 2 screws. Simple panel to cut, opposite side is mirror image can use as as template. But you need the beed rolled on 1 side. I would try Jerry or Alan first unless you have beed roller or access to 1. Quote
PT20J Posted March 2, 2022 Report Posted March 2, 2022 Later models used keyed rivnuts which allow the screws to be tightened more securely. If you use Tinnermans, make sure the sheet metal screws are type B so the thread pitch is correct. Skip Quote
lotsofgadgets Posted March 2, 2022 Report Posted March 2, 2022 I have one off an M20F. I lost half of the fairing on my J and purchased a salvage fairing to get by until I could fabricate/paint a replacement. PM me and we can work something out. Quote
Dick Denenny Posted April 5, 2022 Author Report Posted April 5, 2022 Brought the opposite side in to a paint shop for a match and just was told they have the colors ready in spray cans. Anxious to see if I can match well enough to be satisfied. Will use the same to paint my previous mistake on the the outside wing corner. Was finally able to get a hanger at KCOE and will do it when I get inside. DD Quote
A64Pilot Posted April 5, 2022 Report Posted April 5, 2022 (edited) Oh, do not use sheet metal screws (AKA PK screws) in Tinnerman nut plates, be sure to use Tinnerman screws which do not have a sharp tip. The reason is that the thread pitch and the thickness of the screw body is different, a Tinnerman screw pulls the two bent sections of the nut plate that the threads engage into the body of the screw and that serves as a self locking feature, a sheetmetal screw won’t do that. I believe these are the proper screws https://www.aircraftspruce.com/catalog/hapages/trusstypeb.php Edited April 5, 2022 by A64Pilot 3 Quote
MooneyMitch Posted April 5, 2022 Report Posted April 5, 2022 Hmmmmmm....... All Mooney’s are not the same ......it’s quite possible the mounting holes in a panel from another Mooney might not line up with the existing screw holes in your beauty. And it’s possible they will. Quote
A64Pilot Posted April 5, 2022 Report Posted April 5, 2022 41 minutes ago, MooneyMitch said: Hmmmmmm....... All Mooney’s are not the same ......it’s quite possible the mounting holes in a panel from another Mooney might not line up with the existing screw holes in your beauty. And it’s possible they will. If Mooney’s are like most aircraft, they probably won’t. As skins are almost always hand fit the tolerance stack up makes the final assembly deviate some. Although it’s possible the holes in the trim piece were pre drilled and they were used to locate the nut plates, but usually the nut plates are pre-installed and they determine the location of the holes, so if it fits you got lucky Quote
RobertGary1 Posted April 5, 2022 Report Posted April 5, 2022 Odd mine isn’t like what is described here. Just sheet metal screws into sheet metal. Nothing rubber. Quote
MooneyMitch Posted April 5, 2022 Report Posted April 5, 2022 After gorgeous paint jobs from Artcraft (3 different Mooney’s), prior to re-installing fairings, I lined inner edges with clear adhesive tape in order to prevent paint irritation during empennage movement..... success!! Quote
A64Pilot Posted April 5, 2022 Report Posted April 5, 2022 24 minutes ago, RobertGary1 said: Odd mine isn’t like what is described here. Just sheet metal screws into sheet metal. Nothing rubber. I didn’t see anything about rubber? Quote
A64Pilot Posted April 5, 2022 Report Posted April 5, 2022 19 minutes ago, MooneyMitch said: After gorgeous paint jobs from Artcraft (3 different Mooney’s), prior to re-installing fairings, I lined inner edges with clear adhesive tape in order to prevent paint irritation during empennage movement..... success!! A lot of us will use blue paper painters tape for that purpose because it’s glue doesn’t leave residue 2 Quote
RobertGary1 Posted April 5, 2022 Report Posted April 5, 2022 On 3/1/2022 at 8:54 PM, carusoam said: Don’t forget the bent leading edge and rubber spacers… The sheet metal screws are supposed to grip into a Tinnerman on the inside… Tinnermans probably got old, and stopped gripping… check the other side to see if they are there…. IIRC… PP thoughts only, not a mechanic… Best regards, -a- @A64Pilot and I are wondering about your rubber spacers. I’ve not seen that. Quote
A64Pilot Posted April 5, 2022 Report Posted April 5, 2022 There may be pieces of rubber glued to the underside? Makes sense as would clear abrasion tape Quote
Guest Posted April 5, 2022 Report Posted April 5, 2022 Most of the tail section close out panels that I have encountered are held on with simple self tapping (PK) screws driven into the fuselage side skin and last bulkhead. They started life with #4 diameter screws. Over many Annual inspections the holes wear ever larger, when a #10 screw won’t hold anymore, people instal Riv nuts. I’ve never seen one with plate nuts. Clarence Quote
N201MKTurbo Posted April 5, 2022 Report Posted April 5, 2022 14 minutes ago, M20Doc said: Most of the tail section close out panels that I have encountered are held on with simple self tapping (PK) screws driven into the fuselage side skin and last bulkhead. They started life with #4 diameter screws. Over many Annual inspections the holes wear ever larger, when a #10 screw won’t hold anymore, people instal Riv nuts. I’ve never seen one with plate nuts. Clarence On mine 8 of the 12 are still #4s The top and bottom on both sides have made it to #8s Quote
Guest Posted April 5, 2022 Report Posted April 5, 2022 10 minutes ago, N201MKTurbo said: On mine 8 of the 12 are still #4s The top and bottom on both sides have made it to #8s You must have a good maintainer! I’ve only seen a few with #4 screws. Clarence Quote
carusoam Posted April 6, 2022 Report Posted April 6, 2022 Doc, Have you seen the rubber spacers I reported seeing in my M20C? Looks like somebody sliced a polyurethane tube to occupy the space… They conveniently stuck to the paint so they didn’t get lost through the years… Old fuzzy memories at best… Best regards, -a- Quote
Hank Posted April 6, 2022 Report Posted April 6, 2022 I put Teflon washers under mine--one under the screw head, one between panels. They're great for reducing friction and keeping screw heads from burying themselves in the paint layer. 2 Quote
A64Pilot Posted April 6, 2022 Report Posted April 6, 2022 (edited) 5 hours ago, carusoam said: Doc, Have you seen the rubber spacers I reported seeing in my M20C? Looks like somebody sliced a polyurethane tube to occupy the space… They conveniently stuck to the paint so they didn’t get lost through the years… Old fuzzy memories at best… Best regards, -a- My guess is someone got tired of the paint wear and installed something to prevent it. I hate PK screws and outlawed them on the line I ran, Maule must have stock in them Edited April 6, 2022 by A64Pilot 1 Quote
Jcmtl Posted August 4, 2022 Report Posted August 4, 2022 Does anybody know where in the parts manual this panel can be found? I am missing some screws as well and cannot find this anywhere in the manual. Quote
