My AI just called to see if I had any Aeroshell #6 grease. I don’t. Apparently there is a production problem (fire?) that won’t be resolved until spring, according to a supplier I contacted. It’s a prop grease. So if you are sitting for a case or two, now is your chance to cash in. The supplier said Aeroshell might know of an alternative. Fortunately it’s not a current need of mine.
I understand the production facility for both types burned down.  Aeroshell 5 and 6 is like gold now, if you need it.  Aircraft Spruce had said April at the earliest.
One more data point: my A&P tells me it affects ALL aviation greases :(  His story of the factory burning down matches one of the above.  He is NOT nearly so optimistic about an April recovery...more like, "who knows when???"
  • Sad 1
It’s just as well that Aeroshell #6 is not available. They made a change in its formulation a while back and it is suffering premature separation of the mineral oil. Van’s is reporting the problem too
https://vansairforce.net/community/showthread.php?t=178968
My Hartzell is streaking the blades and throwing on my windscreen. It is currently in a Hartzell shop for a reseal with Nyco GN3058 a lithium synthetic grease.  Hartzell no longer uses Aeroshell on new props
https://hartzellprop.com/SERVICE-DOCUMENTS/SL/HC-SL-61-366.pdf
