54 minutes ago, ArtVandelay said:
There’s one or two threads with installation pictures on MS.
Well maybe, but I looked at every MS GFC 500 thread Google could find before I posted this and didn’t see any. Maybe Google missed it.
Skip
9 hours ago, PT20J said:
Does anyone have pictures of their installation?
Skip
Know I have more but can't find them.  Is there anything specific you want to see?  Next time I have the inspection panel off I'll take more.
Thanks. I wasn’t looking for anything in particular, I was just curious how they are installed relative to the KAP 150.
Skip
Apparently...
With all the barcodes and part numbers....
Big G forgot to make it plain and simple enough to the installer to not mix up...
Getting the hand written notes... Yaw, Roll, Pitch... :)
Great ideas from the field....
2 hours ago, carusoam said:
Apparently...
Actually the servos are all the same and are interchangeable.
  • 5 weeks later...
I'm  hearing that shops that have done several can do the GFC 500 3-servo install in around 50 +/- hours, and another ten for the yaw servo.
I'm still pondering the yaw servo, since the whole job is $80K. Do those that have it in a M20J notice any big difference from the previous autopilot?
Skip
Finally got around to taking more of these for you, Skip [mention=17346]PT20J[/mention].  Apologies for the nighttime lighting and the fact that my bird needs a bath.
What model is this?
Skip
If you are regularly hitting Flight Levels then get the yaw servo.  If looking to draw the amu line somewhere, 86 yaw and just hold a little right rudder in climb out. GFC turns standard rate and I have noticed needs little to no rudder inputs outside of climb out.
5 minutes ago, ArtVandelay said:
Did you have the battery box removed is that a standard installation?
I didn't have it removed.  I have no idea if it's standard or not.  This is how it came from the prior owners.
31 minutes ago, Larry said:
There isn't a battery box in the later Mooneys.  They use a different battery with a slightly heavier case.
That's a misquote, I didn't ask that.  But thanks for the answer!
ZuluZulu: Sorry for the misquote.
