Ever since I got my rocket the baggage door seal has stuck badly to where occasionally we have to reattach the seal. Is it the rubber in the seal that’s failed and is causing this?
Try rubbing silicone grease like DC4 on the face of the seal or the flange of the door to keep them from sticking together, after rebounding the seal to the frame with something like 3 M EC847.
Short term solution:  saran wrap from your kitchen under the seal.  Close the door over night.  Trim with an xacto knife the next morning...no more sticking until the new seal arrives.
Edited by Mooneymite
The seal shouldn’t stick to the door frame especially if you put silicone on it (I like the 100% silicone plumber’s grease - it spreads around easier than DC-4.) I wonder if the seal is deteriorating? Is it an aircraft seal, or something someone put on from Home Depot. I just replaced the cabin and baggage compartment seals on my plane. It’s a real pain getting the old glue off, but reasonably straightforward. Mooney uses Brown Aircraft T-9088 p seal.
Skip
Heat, time, and the seals are not friends...
The rubber material that seals are made of starts to break down... the by-product is a sticky gummy material...
+1 For silicone grease to try to alleviate the challenge... that should work for a while...
Opening the door incredibly slowly sometimes allows the seal to unglue itself... The part that shouldn't be glued....
Unfortunately, Father Time... doesn’t like rubber door seals... in aviation or automobiles....
PP thoughts only, not a silicone seal seller...
