Shipment #1 came in -- Millennium Cylinders, piston pins, alt belt.  Shipment 2 is delayed due to the snow storm but hopefully will be here on Monday or Tuesday.
The 4th cylinder etc. is already @ the shop since we thought it was the cylinder initially based on borescope.
-Don
Whew, rest is finally in! Will be taking to shop tomorrow. Will get an idea of timeframe and if the shop needs anything else… She should be in much better shape after this. DLC lifters are nice…
-Don
FYI, since the re-org of Superior, they have on shore manufacturing with their subsidiary:
https://superioraerospace.net/
I sent an email about where their products are now being machined (after the re-org) and Superior was kind enough to give me the details.
So Superior Aerospace does the manufacture and partial assemblies, while the Dallas (Coppell) Location does the rest.  I live a few miles from their Coppell location too ;o)
-Don
-Don
Quite the saga. Hope all goes well for you Don. You deserve it.  Your positive mental attitude through this is very encouraging. Cheers for smooth running power plant. Scott
I was hoping something like this would have waited a bit longer. I’ve been saving for a big hit but it seems when I go off plan (like leather yokes or autopilot), that is when an event happens. IRAN will freshen things up. I’ve pretty much have done all the other Items as I went along (progressively trying to be ahead of maintenance where it makes sense).
I’m just glad I can do this much now. Bottom end should be good, basically new top end. If all goes well, I should still have leeway later to get the AeroCruze installed. Parts go to the shop tomorrow. The AP/IA doing the engine IRAN has decades of experience (semi-retired last year), has built 3 experimental aircraft (and is building one now), and offered to do this for me (5 years I’ve been going to them). The other AP/IA (who bought the other out) has lots of experience too - but likes to do avionics ;o).
Thanks for checking in!
-Don
Parts dropped off, had a chance to speak to the APs.  They both agree that the lifters must have failed -- intake side. Exhaust showed no signs of issues -- just very odd but not surprising.
Engine is already off, AP is gonna mic the crank and if that is ok (which we don't see a reason why it wouldn't since we caught the metal very early), the IRAN will proceed.
She's naked:
Tear down completed. Crank good, gonna freshen it up with new bearings, rod bolts, lifter plungers, 1 pushrod need’s replacing. Lower mount bushings need replacement. Goes to show things can happen even when maintenance is constantly being done.
We talked about doing the full OH but 3 to 6 months out and she won’t be hangered. I think just doing the IRAN is best for now. It will be as fresh as one can get.
-Don
What they found on tear down:
Spalled lifters happen in the last 60 hours. Last year when we did the #4 cylinder, we saw nothing on the faces/cam.
821 hours since the last IRAN - this is the current condition.
Basically, No NDI (non destructive inspection), and no crank polish/line boring will be done.
-Don
Maybe I’m mistaken, but the coloring of the tappets looks like DLC. I feel like the DLC’s are more black in color. I could be wrong on that…
would be interesting to know for sure but it’s unclear to me when Lycoming started doing the DLC.
Those are the original ones from 1996 when it was a Lycoming factory overhaul. I looked at them and they are not DLC lifters. I also looked at the last IRAN (in 2006 from gear up) and they resurfaced those lifters/cam followers.
When I got the DLC lifters, you could tell the difference. My guess those are just dark from use. The faces are very light color vs the DLC one which are very dark/black faces.
-Don
Here is a pic of the different types - original, DLC (Diamond Like Carbon), Rollers:
-Don
-Don
Spalling due to?   Corrosion?
No corrosion found. We checked the cam and lifters last year and nothing on them. My guess is these 4 just failed recently. I fly pretty much weekly, change the oils ~4 times a year so it’s not from that.
-Don
  • 2 weeks later...
Had to order shorter pushrods. Seems new cam and the Millennium Cylinders may cause tighter tolerances. Seems the shop is getting closer!
-Don
6 months vs ~3 weeks — I had most of the parts, thankfully. So much is new/replaced or recently overhauled- I’m very hopeful on her running well and breaking in quickly. While not a full overhaul, the repair is about as close as one can get… Prop and governor was IRAN’d/resealed by Byams too a couple of years back.… Mag overhauled, SureFly, exhaust overhauled by Dawley before he retired.
Fingers crossed.
-Don
Making progress! Have pics of the cam, this one spalled where the cam rides the case! There has to be something about grinding these particular cams after initial use vs the older 60’s versions. Why would a cam spall where it rides in the case? No lifter to cause this and no evidence of corrosion on the cam… DLC won’t fix that!
Hum….
Hum….
The hydraulic lifter is there to make sure the clearance stays at zero, and if something happens that makes the lifter stick a little full, then there will be pressure on the cam lobe all the way around.   This could also happen if there was maintenance done and somebody swapped the pushrods or replaced a pushrod with one that is too long.
3 lobes on the cam spalled (lifters too), and 2 spalled where the cam rides in the case - glad this was caught early. Prior to the cylinder IRAN first time, no metal to speak of. Metal just started getting higher as time went on after that. Just wondering how it spalled the ‘bearing’ surface of the cam…
-Don
Shop is close to startup!
Here are the expected costs:
  • ~$9800 for 4 new Millennium cylinder kits, piston pins/caps, new cam, DLC lifters, gasket kit, new alternator belt, quick drain(I bought and supplied)
  • ~$2700 for all main and rod bearings, 8 new plungers (lifters), 8 new tappet sockets (plungers), 8 new rod bolts, 8 new rod bolt nuts, 4 new pushrods, 2 new lower engine mount bushings, oil and filter, new spark plug wire, incidentals/shop supplies
  • ~$10,500 labor for annual, remove/reinstall engine ($3250), IRAN engine ($5000), IFR certification ($425), R-N-R electric step, flush oil cooler/lines, running /final engine configurations
  • tax ~$220
Total so far is ~$23,220 for this year’s ‘annual’. Give or take a couple hundred more. Hoping that is it for now but that is an approximate cost based on shops current estimate.
Once initial run is completed  I’ll know for sure.
-Don
  • Like 5
She’s alive! Shop was able to prime and then start her up today! Shop noted right mag needs timing adjustment but all else came out great. Now, waiting for a good weather day to break her in…
-Don
