If you're talking about the tool that enables you to remove the main springs that go into the wing, you really don't need it.
Buy a bunch of cheap washers that are about the thickness of a quarter (1/4 or 5/16" bolt size works well).  Or just use a bunch of quarters and go wash your car after the project is done.
Push those quarters into the spring.  That will keep the spring under tension/extension.  That will allow you to remove the spring from the gear leg and reinstall it after you're done.  Lower the landing gear and all the quarters will drop out.
  • 4 weeks later...
Thanks, Andy. Used this last week for the right main, and will do the left main this week. That was a big help.
