I’m in need of a serviceable bellcrank. Mooney says the will fabricate a -503 “sometime soon” but no real timeline.
Mooney has given me part numbers for replacing the lock bolts but need reference for oversized holes to repair properly.
I’ve heard TopGun in Stockton has repaired and sold these in the past. Anyone have any info on that?
If anyone has a lead on repairing and or availability of a serviceable one let me know. It would be greatly appreciated.
LASAR. Give them a call, I bet there’s a 99% chance they’ll do it.
Then again, there’s not much to them- just hardware and bearings. LASAR can sell you what you need (Dan in parts can probably tell you what you need over the phone).
JOR,
You may have skipped an important detail...
What Mooney do you have?
There may be a used one in an MS hangar... but not all MSers have memorized the part numbers of all the other Mooneys...
Add some detail to your avatar area, when able...
I know a few stashes of used parts I can point you towards...
Thanks for the LASAR suggestion Andy95W, I'm in California so they are usually my first phone call.  They can only order a new part for me...
Carusoam, I did forget the model!  Oops..  I have an M20K 25-001, the part is the bellcrank, furthest aft that connects to both elevators.
