spleecho Posted March 18, 2020 Author Report Posted March 18, 2020 The way I like it....with primary instruments as req. Still don't know how the landing gear warning will work till I fly it. Did a run up last night, all perfect except couple small squawks on the audio panel and I think my OAT is not computing correctly, shows high. Hoping my guy doesn't cancel on friday for static/pitot.
carusoam Posted March 19, 2020 Report Posted March 19, 2020 I like the airspeed data blocks... That is new to me for an engine monitor... More of a flight data monitor with that and gps location combined... Getting the OAT data corrected may be a simple calibration if it is off by a few degrees... Clean connections if off by a lot. Proper TC extensions if needed... Are you familiar with thermocouple wires? Do the wheels go up on the system screen graphic? Best regards, -a-
spleecho Posted March 19, 2020 Author Report Posted March 19, 2020 14 minutes ago, carusoam said: I like the airspeed data blocks... That is new to me for an engine monitor... More of a flight data monitor with that and gps location combined... Getting the OAT data corrected may be a simple calibration if it is off by a few degrees... Clean connections if off by a lot. Proper TC extensions if needed... Are you familiar with thermocouple wires? Do the wheels go up on the system screen graphic? Best regards, -a- Yeah it;s nice to have the TAS computed on the fly and displayed along with airspeed. Important not to use yellow/red colors as they trigger alarms. They hooked it up to the GNS 430 for gps data and engine monitor also sends fuel data to 430 for it's own trip fuel planning. As far as OAT I believe the error is in the calculation factor from raw data as its not off by certain degrees but rather multiplied as it increases. will worry about that one later tho not a biggie.I didn't get a chance to see wheels go up on the screen, but I really hope they do was nervous with the plane on jacks when they were swinging the gear 1
spleecho Posted March 23, 2020 Author Report Posted March 23, 2020 Well I’m happy to report she’s all done. Paperwork in logbook and test flights went perfect, no squawks and no adjustments! Was perfect! 2
carusoam Posted March 23, 2020 Report Posted March 23, 2020 Screen looks quite clear... I can Read it from more than 1kmi away! Great job! Thanks for sharing the details. What’s next? Flight hours required for insurance? A real CO monitor? Some in flight pics by the SIC? Best regards, -a-
gsxrpilot Posted March 23, 2020 Report Posted March 23, 2020 @spleecho it looks great. But do yourself and your passengers a favor and get rid of that CO dot. Get a proper CO detector. Friends don't let friends fly with just the Dot. 1
spleecho Posted March 23, 2020 Author Report Posted March 23, 2020 I have few hundred hours in this Mooney already so insurance wise I’m good. As far as CO2 monitor I still have and use the Foreflight’s Sentry with crazy loud audible alarm and works very well, plan on continuing to use just for that. More pics to come soon, Did about 6-7 touch n go’s and 3 high speed taxi’s done, on last taxi I got a bit too excited and ended up taking off. Just stayed in pattern in case something went wrong. Very pleased! 4
gsxrpilot Posted March 23, 2020 Report Posted March 23, 2020 1 hour ago, spleecho said: As far as CO2 monitor I still have and use the Foreflight’s Sentry with crazy loud audible alarm and works very well, plan on continuing to use just for that Excellent.
jwarren2 Posted March 23, 2020 Report Posted March 23, 2020 Great looking panel,,,,,, I'm jealous. However, I've been following this thread and you have given me the inspiration that I need. Thanks. 2
Guest Posted March 23, 2020 Report Posted March 23, 2020 You can start working on the left panel when you start your social distancing. I can tell you that you can fit the HSI Centred above the yoke shaft and still fit the AI above that. Clarence
jwarren2 Posted March 24, 2020 Report Posted March 24, 2020 13 hours ago, M20Doc said: You can start working on the left panel when you start your social distancing. I can tell you that you can fit the HSI Centred above the yoke shaft and still fit the AI above that. Clarence Would you happen to have a picture? I have the dual G5s and want to do something with my left panel but can't seem to make it work unless I offset the stacked G5s to the left of the yoke shaft. Once I do this, I lose my 2.250" hole for a clock or whatever I would chose to use that space for. Of course this is all on paper so far, so I'm allowed a few mistakes.
Guest Posted March 24, 2020 Report Posted March 24, 2020 8 hours ago, jwarren2 said: Would you happen to have a picture? I have the dual G5s and want to do something with my left panel but can't seem to make it work unless I offset the stacked G5s to the left of the yoke shaft. Once I do this, I lose my 2.250" hole for a clock or whatever I would chose to use that space for. Of course this is all on paper so far, so I'm allowed a few mistakes. I sold the airplane sometime ago. I'll see if I have any pictures, however I managed to fit a Narco DGO 10 HSI and a standard vacuum AI in both above the control column. I'm not sure how big the face of the G5 is to know if it can be done. Clarence
jwarren2 Posted March 25, 2020 Report Posted March 25, 2020 15 hours ago, M20Doc said: I sold the airplane sometime ago. I'll see if I have any pictures, however I managed to fit a Narco DGO 10 HSI and a standard vacuum AI in both above the control column. I'm not sure how big the face of the G5 is to know if it can be done. Clarence Ok,, thanks .
spleecho Posted March 30, 2020 Author Report Posted March 30, 2020 Went for $100 burger. Flew perfect and engine gauges no issues. Very happy with it. 2
carusoam Posted March 30, 2020 Report Posted March 30, 2020 Who took care of the video for you? That looks great! Best regards, -a-
spleecho Posted March 30, 2020 Author Report Posted March 30, 2020 33 minutes ago, carusoam said: Who took care of the video for you? That looks great! Best regards, -a- Buddy always takes videos 1
Nukemzzz Posted May 18, 2020 Report Posted May 18, 2020 Nice work! That big open space is really asking for either an iPad mount or a document pouch. Are you saving it for future additions? I’m thinking of starting on something similar while my engine is out, because I like to torture myself. Lol Struggling with what to do on mine because I need to shift some things from co pilot to pilot side so I can’t just do one side at a time.
spleecho Posted May 18, 2020 Author Report Posted May 18, 2020 13 hours ago, Nukemzzz said: Nice work! That big open space is really asking for either an iPad mount or a document pouch. Are you saving it for future additions? I’m thinking of starting on something similar while my engine is out, because I like to torture myself. Lol Struggling with what to do on mine because I need to shift some things from co pilot to pilot side so I can’t just do one side at a time. I decided to keep it open for now. I did try with temporary iPad mount there but the angle is so far off that it makes it useless
