Comments to this “news” are classic.  Face palm.  So pilot has a loss of power and executes a successful water landing.  Were the minor injuries getting their feet wet while standing on the wing?  Good thing they were rescued.  Had more than their feet gotten wet....oh the humanity.
Nice job pilot.  Sorry the idiocracy got in the way of your apparent flawless execution of a water landing necessitated by a loss of power.
Expand
Hey, maybe we can promote this as "The Miracle on the Marsh". :D
  • Haha 2
Spoke with the pilot on FB and was told the this was the first flight on the plane after annual.  Engine failed about 1.5 mile final forcing them to ditch short of the runway.  Passenger had a broken arm and the pilot had a 10 inch gash to the side of his head.  He also advised me that the water comes into the cockpit really quick.  Thankfully it was shallow water and they both got out okay.
Expand
Sorry about the injuries.  GLAD they are/were not life altering.  I appreciate having actual information.  Are you stating that the water was so shallow that they could stand on the wing while the airframe was resting on the bottom?  Did both pilot and passenger have shoulder harness?  If water is deeper than 64”’s it might as well be a mile because I can’t stand and breath.  Any window of time on “really quick”?
Expand
I am not aware of the exact depth there in that marshy area, but the pictures of the plane show that it had settled mostly above water.  As for shoulder harnesses, I did not ask but I think (correct me if I am wrong) shoulder harnesses were standard on the mid 80's 20J.  He did not expand on the words "really quick" and I know I personally do not want to test how fast it is.  LOL
I am thinking of filling the wings with floating material for long term flotation. Or sealing the wings outside the fuel tanks. What do you think?
Edited by Gagarin
Expand
I would be very interested in reading a write-up on the incident.  My questions?  Did harnesses get worn?  Did the grass grab the plane and cause a partial spin that resulted in the head and arm injury?  How long did it take for the plane to submerge?  Sorry I did not watch the video I just read the story.  Had I done so I would of known the plane was only partially submerged and that an occupant had a fracture to an arm.  Again, glad they received a rapid response/rescue.  Glad injuries were not severe.  Sorry for the loss of his airframe.  Maintenance induced failure?  We shall see.
Expand
You could fill the wings with ping pong balls, buoyant, non toxic and easily removed.
Expand
Yikes!  Have you ever seen ping pong balls burn? Sure they float, but a wing full, should they catch fire, would create quite an impressive inferno!
Expand
While true, Jose’ would treat his balls with some special concoction of flame retardant chemical from Walmart!
  On 11/12/2019 at 8:35 AM, ArtVandelay said:
They weren’t made of lightweight wood and I’m betting they were carrying heavy cargo like cannons, anchors, etc
Expand
And woodwing Mooney pilots sat on the wooden floor, carried no baggage, had neither chrome-moly steel safety frame nor push-pull control rods, magical lightweight engines and balsa wood propellors . . . .
How does the basuc empty weight of an M20-A compare to that of an M20-B with metal tail conversion per AD? Thst will tell the truth about "wood floats" . . . . But ducks also float. Why? Because they made of _____.  :D
Expand
Thanks for the detail.  Look forward to hearing more.  Not surprised that water rushes in- non-pressurized aircraft leak like a sieve.
  On 11/11/2019 at 11:52 PM, kerry said:
I believe the above picture is a wood wing Mooney and wood floats.
Expand
So do empty fuel tanks.   I would guess this plane was full of fuel.   Only thing salvageable is the antennas.
  On 11/12/2019 at 7:32 PM, Gagarin said:
The access panels are sealed with custom made gaskets.
Expand
Water still runs in between the wing lap seams. The trailing edge spar. That’s not watertight.  The aileron pushrod exit hole. The entire belly. The landing gear wells have several fist size holes in them.  No.
Could someone meet this flotation objective using multiple inflatable air bladders within the lateral wings maybe?  They would have to be easily deflated and removed for maintenance and inspection.
But I suspect someone will easily deflate this idea as well :lol:.
Edited by DXB
