Welcome aboard JD.
Many have had this done...
It is a bit complex depending on a couple of things...
1) what plane you have...
2) what avionics you have...
Other than that, how else can we help you out?
3) Some standardized Mooney choices are available at Lasar...
4) If you search around here there was an MSer named Hendricks Manufacturing that had a couple of Mooney panels designed and made available....
Other than that... if you have a larger budget and are planning a 50amu panel update... start with your instrument shop...
