Works perfect. Complete with tray and connector $1700
Frank
760 424 2058
Trig’s TT31 transponder is the perfect retro-fit for the popular Bendix King KT76A and KT78A transponders. The TT31 is a certified Class 1 transponder which will ‘plug and play’ straight into the existing Bendix King tray. This significantly reduces both installation time and cost. It provides pilots with class leading Mode S technology that is also 1090ES ADS-B Out capable too (ADS-B functionality requires a Trig tray).
  • Retrofit – ‘plug and play’ installation for KT76A and KT78A transponders
  • Certified Mode S and 1090ES ADS-B Out capable
  • Certified for IFR / VFR flight
  • Lowest power consumption in class
  • 240 watts nominal output
  • Great functionality and performance - TIS traffic capabilities
  • Backlit LED display
  • No cavity tube – no warm up time required
  • No need for dropper resistors
  • EASA ETSO and FAA TSO Certification - includes TSO C166b the latest ADS-B standard
  • Unbeatable value and quality - designed and manufactured in the U.K.
  • Two year worldwide warranty
If 1090ES out (such as we are getting in Canada) requires a Trig tray, can you tell us whether the tray shown in the pictures is such a tray?
The Transponder comes with the original TRIG tray. The difference between the TRIG and KT76A tray is the second molex connector and the word TRIG stenciled in the top og the tray.
As long as you have a TSOd WAAS position source , you are good ,   Remember , if you have a turbo , you cant use the beacon , or the GDL 82 , or GDL 88 …. This is dual out so it is good over 18K feet
