Sixstring2k Posted January 5, 2019 Report Posted January 5, 2019 I rather inspect and be sure or not purchase a suspect plane than end up on a NTSB report, those reports never end well.
Nippernaper Posted January 5, 2019 Report Posted January 5, 2019 My recently purchased j had a prop strike last year, with a full tear down inspection. Crank was found to be OK, but cam was reground. I would not have purchased without the teardown. As stated above, the risk is the introduction of cracks that can grow over time due to fatigue until a brittle fracture occurs during flight. For those who think a tear down is not required, ask yourself what rate of failure due to an uninspected strike would be acceptable to you, 1:30? 1:60? 1:100? If you find 100 pilots still flying behind an uninspected crank after a strike, does that really tell you anything useful? TomSent from my iPhone using Tapatalk
Nippernaper Posted January 5, 2019 Report Posted January 5, 2019 Why does Beechtalk have a picture of a Piper Arrow posted?thought those guys only cared about planes with V Tails That doesn't look like an arrow to me; more like a bo or debbie.Sent from my iPhone using Tapatalk 1
EricJ Posted January 5, 2019 Report Posted January 5, 2019 1 hour ago, Nippernaper said: That doesn't look like an arrow to me; more like a bo or debbie. It's one of those Beechcraft Arrows. 1
orionflt Posted January 5, 2019 Report Posted January 5, 2019 4 hours ago, Nippernaper said: My recently purchased j had a prop strike last year, with a full tear down inspection. Crank was found to be OK, but cam was reground. I would not have purchased without the teardown. As stated above, the risk is the introduction of cracks that can grow over time due to fatigue until a brittle fracture occurs during flight. For those who think a tear down is not required, ask yourself what rate of failure due to an uninspected strike would be acceptable to you, 1:30? 1:60? 1:100? If you find 100 pilots still flying behind an uninspected crank after a strike, does that really tell you anything useful? Tom Sent from my iPhone using Tapatalk I would have insisted on a new Cam instead of grinding it, I know it's been recoated and with in specs but I haven't seen them last. mine was reground at overhaul by the previous owner and I ended up replacing it at under 600 hour. Brian
Nippernaper Posted January 5, 2019 Report Posted January 5, 2019 Didn't have a choice; was done well before the purchase. Doing what I can to protect the cam.Sent from my iPhone using Tapatalk
Arthur Posted January 6, 2019 Author Report Posted January 6, 2019 Thanks all for your input. I think I will still continue to let these planes pass until I find the one I want.
bob865 Posted January 7, 2019 Report Posted January 7, 2019 I think I've told this story here, but I think which decision made says something about the owner too. My plane had a prop stike and had a full teardown inspection after and the owner flew for hundreds of hours before I bought it. Generally a safe pilot. When his health failed, he stopped flying. Never knew of the guy to take any chances flying either. Pretty well known around the airport. And I've had no issues since I've had it. However, another Mooney driver at the airport started talking with me one day. I had looked up his plane online and knew that it had been sold at salvage following a gear up landing. When I mentioned it, he was proud of the fact that didn't do all the "extra" work for the prop strike and only replaced the stuff required by the AD. Gave off the "Vibe" that anyone who would do whole teardown was a sucker. He was also proud that he didn't have hardly any damage and only repaired a couple of panels from the gear up. This guy then went on to almost have an incident on takeoff when he took off without sumping his tanks and got water into the engine and then actually had an incident when he departed the runway landing at Myrtle Beach.
Yetti Posted January 7, 2019 Report Posted January 7, 2019 A broken crankshaft is the result. I would only fly a propstrike that had the crankshaft NDTed
Sixstring2k Posted January 8, 2019 Report Posted January 8, 2019 12 hours ago, bob865 said: I think I've told this story here, but I think which decision made says something about the owner too. My plane had a prop stike and had a full teardown inspection after and the owner flew for hundreds of hours before I bought it. Generally a safe pilot. When his health failed, he stopped flying. Never knew of the guy to take any chances flying either. Pretty well known around the airport. And I've had no issues since I've had it. However, another Mooney driver at the airport started talking with me one day. I had looked up his plane online and knew that it had been sold at salvage following a gear up landing. When I mentioned it, he was proud of the fact that didn't do all the "extra" work for the prop strike and only replaced the stuff required by the AD. Gave off the "Vibe" that anyone who would do whole teardown was a sucker. He was also proud that he didn't have hardly any damage and only repaired a couple of panels from the gear up. This guy then went on to almost have an incident on takeoff when he took off without sumping his tanks and got water into the engine and then actually had an incident when he departed the runway landing at Myrtle Beach. It sounds like this guys like living on the edge, hope his luck holds.
