TheTurtle Posted September 1, 2018 Report Posted September 1, 2018 Just got my prop overhauled. Started it (on the first blade) and did a full runup. Everything good. Call the gas guy. Load up the friends. Try a hot start. wont start. Kept trying but the push to start in the switch was getting more and more finicky. Had to do little jiggles and side push to get the starter to engage. Finally it wont throw the starter out at all. I can hear the shower of sparks noise and when I press in I just hear a click/clunk but nothing happens. Unloaded pax. Drove. grumble. My mechanic happened to be working in his hangar listening to me try to start it. He said I need a new shower of sparks. Seems to me I can hear it doing its shower thing. My ignition switch has always been finicky. But as I sit here typing I'm wondering if I overheated the starter. This would be by far not the longest I cranked it but ... I think I'm going to go over to the field today and see if it will turn over now that the starter has cooled off. Thoughts? Quote
N201MKTurbo Posted September 1, 2018 Report Posted September 1, 2018 What starter do you have? 1 Quote
cliffy Posted September 1, 2018 Report Posted September 1, 2018 First indication is the starter switch. If you had to "jiggle" it to make it run, start here. Most can be taken apart and cleaned and lubed. If its broken, replace it ($$). If the prop won't turn (starter dead) it ain't the SOS. Have your A&P jump the leads on the start solenoid to see if the prop will turn. Check battery charge (hydrometer check), start solenoid check for high resistance, all battery cables to starter for good clean connections AND make sure you have a good ground wire from the battery to the airframe. 2 Quote
TheTurtle Posted September 1, 2018 Author Report Posted September 1, 2018 43 minutes ago, N201MKTurbo said: What starter do you have? not sure. its not one of the hightorque light weight ones though. Quote
N201MKTurbo Posted September 1, 2018 Report Posted September 1, 2018 2 hours ago, TheTurtle said: not sure. its not one of the hightorque light weight ones though. If you have the original Prestolite and you don’t hear it spinning, you probably need a new solenoid. If you do hear it spinning you probably need a new bendix. If it is the bendix, you can try hosing it down with Tri-flo or silicon. Don’t use anything that leaves an oily residue it will just collect dirt and make it worse. Quote
ArtVandelay Posted September 1, 2018 Report Posted September 1, 2018 If it is the bendix, you can try hosing it down with Tri-flo or silicon. In my experience that’s a very temporary solution and will fail when you are away from home. 1 Quote
N201MKTurbo Posted September 1, 2018 Report Posted September 1, 2018 2 minutes ago, teejayevans said: In my experience that’s a very temporary solution and will fail when you are away from home. Yep, I agree completely. But it may get you going for a while. If you get stuck away from home, use a long screwdriver to manually engage the bendix. Easy on an F quite a bit harder on a J. Quote
Guest tommy123 Posted September 2, 2018 Report Posted September 2, 2018 Find another mechanic that guy doesn’t have a clue. Quote
TheTurtle Posted September 2, 2018 Author Report Posted September 2, 2018 8 hours ago, tommy123 said: Find another mechanic that guy doesn’t have a clue. He wasnt talking about it not turning over at all at the end. Its the fact it was being such a bitch to start to begin with. Quote
bonal Posted September 2, 2018 Report Posted September 2, 2018 21 hours ago, cliffy said: First indication is the starter switch. If you had to "jiggle" it to make it run, start here. Most can be taken apart and cleaned and lubed. If its broken, replace it ($$). If the prop won't turn (starter dead) it ain't the SOS. Have your A&P jump the leads on the start solenoid to see if the prop will turn. Check battery charge (hydrometer check), start solenoid check for high resistance, all battery cables to starter for good clean connections AND make sure you have a good ground wire from the battery to the airframe. This Quote
ShuRugal Posted September 2, 2018 Report Posted September 2, 2018 18 hours ago, teejayevans said: In my experience that’s a very temporary solution and will fail when you are away from home. I've had the opposite experience - when i got my C model last fall, it would "ziing" in cold weather on the first attempt, then engage on the second. Hosed it with some tr-flow, and haven't had a problem with it since December. Quote
TheTurtle Posted September 4, 2018 Author Report Posted September 4, 2018 Good news. I think I just overheated the starter. Went out today and it fired up on the second blade. Now to figure out why shes being such a bitch hot starting lately. I thought I had my hot start method down pretty well but even that is failing me the last couple months. 1 Quote
carusoam Posted September 4, 2018 Report Posted September 4, 2018 Try to define a hot start... If you ran the engine a few minutes to get to the fuel pump... pulled the mixture to kill it... It probably isn’t a hot-start, is it? Best regards, -a- Quote
asaxet Posted September 4, 2018 Report Posted September 4, 2018 I found David's process very productive with my E... search google for "Hot Starts M20E interview with David McGee" Im usually running in 1 or 2 start attempts of 15secs of starter engagement... Just get in the habit of 1000 rpm shut downs... that throttle position works well for myh cold starts too... 1 Quote
MyNameIsNobody Posted September 8, 2018 Report Posted September 8, 2018 On 9/3/2018 at 7:05 PM, TheTurtle said: Good news. I think I just overheated the starter. Went out today and it fired up on the second blade. Now to figure out why shes being such a bitch hot starting lately. I thought I had my hot start method down pretty well but even that is failing me the last couple months. I have a technique, but we are talking black inky magic on the hot start of my E. I can get it started, but sometimes it is pretty “cranky” if you get my gist... Good for you that you have it “down” pretty good. Me? Not so much. 1 Quote
LANCECASPER Posted September 8, 2018 Report Posted September 8, 2018 On 9/3/2018 at 7:05 PM, TheTurtle said: Good news. I think I just overheated the starter. Went out today and it fired up on the second blade. Now to figure out why shes being such a bitch hot starting lately. I thought I had my hot start method down pretty well but even that is failing me the last couple months. Nothing has fixed itself though. Whatever it is, it is so much cheaper and convenient to get it taken care of at your home field rather than getting stuck somewhere. Usually you get some warning signs before a starter goes completely. I think a new starter is in your future. 1 Quote
FloridaMan Posted September 10, 2018 Report Posted September 10, 2018 I had a similar issue. Turns out a wire had fallen off the slickstart. Check the fuse and breakers before digging further. Quote
Guest Posted September 10, 2018 Report Posted September 10, 2018 Search the Continental website for the SoS manual. It has testing, repair and parts break down. Basic operational check in the plane is fairly easy as well. Clarence Quote
St64 Posted September 11, 2018 Report Posted September 11, 2018 Check out Don Maxwell's YouTube video on hot starts. Quote
N9434V Posted September 11, 2018 Report Posted September 11, 2018 (edited) My experience with Shower of Sparks. 1) if your battery is weak your Shower of Sparks (SOS) will be weak and may not provide enough spark to start 2) If you release the starter while engine is spinning this will allow the mags to do their thing and thus probable the engine will start -- The (SOS) system shorts out the mags, which is problematic with both a weak battery and the SOS not working. 3) It is my belief that if the SOS is buzzing it is working, albeit with a weak battery may not be producing sufficient spark to start. 4) If the spark plugs have too much resistance, as in old or partially fouled, they could also cause a need for more electric pulse than the SOS is providing. 5) there is a set of points within the SOS that sometimes need cleaned/filed -- SOS manual referenced above does give the point gap setting. Just a PPL so the above is not gospel but just my experience/opinions, but number 1 above causes all kinds of problems with the SOS. Good luck Edited September 11, 2018 by N9434V 1 Quote
