N231BN Posted September 15, 2018 Report Share Posted September 15, 2018 I agree with others that this is common in Continentals. I disagree that it is acceptable however and it usually can be remedied. Quote Link to comment Share on other sites More sharing options...
PMcClure Posted September 15, 2018 Report Share Posted September 15, 2018 Just to add a few comments to this discussion. I have a 2002 O2 and had the same issues. I took the plane to TCM and had the adjust the fuel settings twice. All settings were adjusted correctly, but the problem continued. It only happened after a +1 hour flight and only after landing. Another problem developed where the engine would not shut down after pulling the mixture. It would kind of diesel and keep running at the ramp. The corrective action for this was a rebuild of the spider valve on top of the engine. This correction fixed both issues and it has been almost 2 years since either has presented itself. When I am back at the hangar, I will double check if there was any other work done at the same time. Quote Link to comment Share on other sites More sharing options...
N231BN Posted September 15, 2018 Report Share Posted September 15, 2018 Just to add a few comments to this discussion. I have a 2002 O2 and had the same issues. I took the plane to TCM and had the adjust the fuel settings twice. All settings were adjusted correctly, but the problem continued. It only happened after a +1 hour flight and only after landing. Another problem developed where the engine would not shut down after pulling the mixture. It would kind of diesel and keep running at the ramp. The corrective action for this was a rebuild of the spider valve on top of the engine. This correction fixed both issues and it has been almost 2 years since either has presented itself. When I am back at the hangar, I will double check if there was any other work done at the same time. That is also the cheapest item to replace in the system and should be done first if having any problems. Quote Link to comment Share on other sites More sharing options...
mike_elliott Posted September 15, 2018 Report Share Posted September 15, 2018 HI Brian, Clarence is spot on here, and Mr. Mclures suggestion to have the fuel divider examined if following the SB doesnt cure this anomaly makes sense. Ill see you next month! Mike Quote Link to comment Share on other sites More sharing options...
