Guest Spike Kavalench
FYI guys, Alan is a straight shooter. I called him about a used throttle cable, explained the symptoms, and he said immediately:  “You don’t need a cable” and went on to explain how to fix my issue and talked me out of buying a cable from him. This should also get me back flying a lot sooner, so a big THANK YOU to Alan for that!
I’m going to assume your Fuel Servi went with the engine, but thought I’d check anyhow.
I have one off of a 200 HP Arrow ,  if its the same
Not sure if the -11 and -9 model numbers would be Interchangeable or not. But, that’s what I’m pulling off the Precision website.
I sold the servo to a rebuilder yesterday
No worries. Mine is being sent out for overhaul as we speak. Thanks.
