Jerry Pressley Posted March 23, 2018 Report Posted March 23, 2018 Now I am confused!!!!! I looked at the above listed AD very closely and could not find a reference to serial numbers not affected. Only the A and B hub are exempt. And the required peening refers to the blade shank as far as I can find. Cant find anywhere peening is required on the hub. Of course the prop shops I checked with could be wrong but i would really like to show them documentation to prove them wrong.
Jerry Pressley Posted March 23, 2018 Report Posted March 23, 2018 one more little consideration....if you have a prop strike of any sort with that nice new hefty B hub then you are hung for another hub if the blades are usable as is the case in a great number of instances. The B hub has a flange that gives way with pressure on the shank in almost every instance of strike. The eddy current ones had a heavier flange and in most cases are reusable. I owned a prop shop for years so this is not just blowing smoke. Would be glad to show you an example of each hub.
salty Posted March 23, 2018 Report Posted March 23, 2018 7 minutes ago, acpartswhse said: one more little consideration....if you have a prop strike of any sort with that nice new hefty B hub then you are hung for another hub if the blades are usable as is the case in a great number of instances. The B hub has a flange that gives way with pressure on the shank in almost every instance of strike. The eddy current ones had a heavier flange and in most cases are reusable. I owned a prop shop for years so this is not just blowing smoke. Would be glad to show you an example of each hub. Want to buy my old hub?
