40 minutes ago, larryb said:
Have you ever worked with that product? It works well but is hard to put on and hard to get off and will scratch the paint. It is more of a permanent thing. The spiral wrap I use or the braid Layton used is a much easier solution. I have not seen any degradation.
I have on my kit build.  There are a varying width grommets for sheets of different thickness.  If you get the right size, it can be pretty easy to get on and off.
