jaylw314 Posted June 12, 2017 Report Posted June 12, 2017 (edited) I have a GPS annunciator lamp for my Garmin 530W that burned out. The bulb is some weird type I cannot find for sure on the internet. It has "WT-7046" stamped on the base. A search for the ID on Google was a fail. The closest I could find was WAMCO's WL-565-101, which looks right (the second photo). However, it looks like it actually has "WL-565-101" stamped on the base. It's also $64 on Skygeek, although I found it at Newark for $10. Anyone seen this before and can confirm the part numbers? I'm kind of annoyed that they didn't just use a standard bulb. Edited June 12, 2017 by jaylw314
N201MKTurbo Posted June 12, 2017 Report Posted June 12, 2017 http://www.cessnadirect.com/7046.html http://www.aeroval.com/ref/469248/7046 if it looks like a duck and quacks like a duck.....
RobertGary1 Posted June 13, 2017 Report Posted June 13, 2017 Do you have a Garmin manual that legally describes how to replace that light bulb? -Robert
jaylw314 Posted June 14, 2017 Author Report Posted June 14, 2017 5 hours ago, RobertGary1 said: Do you have a Garmin manual that legally describes how to replace that light bulb? -Robert No, the Garmin install manual only specifies the pinouts for the annunciator, and leaves it up to the A&P to determine what annunciator to install and how.
jaylw314 Posted June 21, 2017 Author Report Posted June 21, 2017 So, as it turns out, this is a T1 lamp with a base type called a "Pogo" for obvious reasons. The WL-7049 is unfortunately a 24V lamp, so at 12V it is too dim. There is a series of bulbs from WAMCO listed as WL-7041, WL-7043, WL-7049 and WL-565-101 which are either 24v or 5v bulbs. Some are also made by Chicago Miniature and listed as CM-7049. It turns out the 7046 bulb is the only 12v bulb, and is used as a flap indicator light on some Mooney's, and listed as WI-7046 (made by Western Instruments). But for the life of me, I cannot find any suppliers. I think that means I need to have my A&P replace the light with a different annunciator. Can I just order one of these and have him replace it?
Guitarmaster Posted June 26, 2017 Report Posted June 26, 2017 On 6/21/2017 at 4:26 PM, jaylw314 said: So, as it turns out, this is a T1 lamp with a base type called a "Pogo" for obvious reasons. The WL-7049 is unfortunately a 24V lamp, so at 12V it is too dim. There is a series of bulbs from WAMCO listed as WL-7041, WL-7043, WL-7049 and WL-565-101 which are either 24v or 5v bulbs. Some are also made by Chicago Miniature and listed as CM-7049. It turns out the 7046 bulb is the only 12v bulb, and is used as a flap indicator light on some Mooney's, and listed as WI-7046 (made by Western Instruments). But for the life of me, I cannot find any suppliers. I think that means I need to have my A&P replace the light with a different annunciator. Can I just order one of these and have him replace it? Did you check Digikey and Mouser?
mlrdz Posted December 3, 2024 Report Posted December 3, 2024 old topic but I just found these on Digikey, part number WL-7046
