ragedracer1977 Posted June 7, 2017 Report Posted June 7, 2017 (edited) I was getting a quote for a couple things... Edited June 7, 2017 by ragedracer1977 Quote
Marauder Posted June 7, 2017 Report Posted June 7, 2017 I was getting a quote for a couple things... Maybe if they drop the "1" in front. Why would anyone upgrade a 330 when you can buy a new GTX-345 for ~$6,500 installed?Sent from my iPhone using Tapatalk Pro Quote
donkaye Posted June 7, 2017 Report Posted June 7, 2017 4 minutes ago, ragedracer1977 said: I was getting a quote for a couple things... Definitely a typo on the GTX 330ES or a fraud. The other costs are about right. My understanding is that it is about $1,500 to upgrade the GTX 330 to the GTX 330ES. 1 Quote
ragedracer1977 Posted June 7, 2017 Author Report Posted June 7, 2017 I questioned the install times a little as well. 10 hours to install the USB port and 6 hours for the cigarette lighter. Seems like double dipping a little. Quote
N6758N Posted June 7, 2017 Report Posted June 7, 2017 33 minutes ago, Marauder said: Maybe if they drop the "1" in front. Why would anyone upgrade a 330 when you can buy a new GTX-345 for ~$6,500 installed? Sent from my iPhone using Tapatalk Pro Because if you already have a 330 it should be around 2,200 installed to get it to a 330ES. So $4,300 is a pretty good reason... Quote
Marauder Posted June 7, 2017 Report Posted June 7, 2017 Because if you already have a 330 it should be around 2,200 installed to get it to a 330ES. So $4,300 is a pretty good reason... I was referring to the $12,000 upgrade cost. Why would you upgrade a 330 to ES for $12,000 when you can install the 345 for ~$6,500?Sent from my iPhone using Tapatalk Pro Quote
N6758N Posted June 7, 2017 Report Posted June 7, 2017 Just now, Marauder said: I was referring to the $12,000 upgrade cost. Why would you upgrade a 330 to ES for $12,000 when you can install the 345 for ~$6,500? Sent from my iPhone using Tapatalk Pro Haha I thought so, that has to be a typo. Either that or they must think the OP is really gullible. Quote
Piloto Posted June 7, 2017 Report Posted June 7, 2017 I am going to keep my KT 76 a little bit longer. Waiting for the Chinese ADS-B. José Quote
Godfather Posted June 7, 2017 Report Posted June 7, 2017 I'm sure the price has an extra zero. 1200 for the upgrade and 2200 for the exchange. Quote
ragedracer1977 Posted June 8, 2017 Author Report Posted June 8, 2017 2 hours ago, N6758N said: Because if you already have a 330 it should be around 2,200 installed to get it to a 330ES. So $4,300 is a pretty good reason... He wants $1900 for the install, plus $850 to "remove interior" as required, plus 10% of the total cost for shop supplies. So assuming he meant $1200 for the upgrade, id be looking at somewhere around $4200. Personally I think that's way out of line from what I've seen Quote
bradp Posted June 8, 2017 Report Posted June 8, 2017 R&Ring the interior on the pilots side takes about 1-2 hrs total. I wish I could get paid $400/hr to remove 45 screws :-). Seats take about 10-15 minutes. Quote
N6758N Posted June 8, 2017 Report Posted June 8, 2017 43 minutes ago, ragedracer1977 said: He wants $1900 for the install, plus $850 to "remove interior" as required, plus 10% of the total cost for shop supplies. So assuming he meant $1200 for the upgrade, id be looking at somewhere around $4200. Personally I think that's way out of line from what I've seen Thats a bunch of BS, find another shop. He doesn't need to remove the interior for the 330ES install. For that its a matter of adding two wires to your WAAS source. We used to charge 4 hrs of labor plus the cost of the upgrade from Garmin for a 330 to 330ES conversion. Including the 330ES, FS 210, and cig lighter/USB you should be looking somewhere around 12hrs total labor. Quote
thinwing Posted June 8, 2017 Report Posted June 8, 2017 3 hours ago, Piloto said: I am going to keep my KT 76 a little bit longer. Waiting for the Chinese ADS-B. José You planning on doing all your flying in China in 2020? Quote
ragedracer1977 Posted June 8, 2017 Author Report Posted June 8, 2017 13 minutes ago, N6758N said: Thats a bunch of BS, find another shop. He doesn't need to remove the interior for the 330ES install. For that its a matter of adding two wires to your WAAS source. We used to charge 4 hrs of labor plus the cost of the upgrade from Garmin for a 330 to 330ES conversion. Including the 330ES, FS 210, and cig lighter/USB you should be looking somewhere around 12hrs total labor. HAHHAHHAHHHA! He quoted 53 hours of labor. 22 for the transponder. 10 hours to remove interior. 10 hours for the USB. 5 hours for the Flightstream 210. 6 hours for the cigarette lighter. I think maybe I should look around for a different avionics guy..... Quote
LANCECASPER Posted June 8, 2017 Report Posted June 8, 2017 Clearly he doesn't want the job. If he did he would have looked over the quote. The ES upgrade is $1200 not $12000. Quote
Godfather Posted June 8, 2017 Report Posted June 8, 2017 When I had my 327 upgraded to the 330es it took one guy a solid day with another person helping out on and off. I was at the shop and the installer was working hard and stayed after ~ an hour to finish the job. Quote
Yetti Posted June 8, 2017 Report Posted June 8, 2017 The official Mooney Cigarette lighter plug is just a $5.29 metal one from Autozone. It sits really close to the breakers. Should take no longer than 30 minute to cut a hole and wire it in http://www.truevalue.com//catalog/product.jsp?productId=40995&parentCategoryId=0&type=product&cid=gooshop&source=google_pla&9gtype={ifsearch:search}{ifcontent:content}&9gkw={keyword}&9gad={creative}.1&9gpla={placement}&ctcampaign=4680&ctkwd={product_id}&ctmatch=&ctcreative={Creative}&ctcampaign=4660&ctkwd=&ctcreative=44622122499&ctplacement=&ctadpos=1o5&ctmatch=&ctlocid=9027618&cttrgtid=pla-294682000766&ctfeedid=&ctnwk=g&ctdevice=c Quote
ragedracer1977 Posted June 8, 2017 Author Report Posted June 8, 2017 Just now, Yetti said: The official Mooney Cigarette lighter plug is just a $5.29 metal one from Autozone. It sits really close to the breakers. Should take no longer than 30 minute to cut a hole and wire it in http://www.truevalue.com//catalog/product.jsp?productId=40995&parentCategoryId=0&type=product&cid=gooshop&source=google_pla&9gtype={ifsearch:search}{ifcontent:content}&9gkw={keyword}&9gad={creative}.1&9gpla={placement}&ctcampaign=4680&ctkwd={product_id}&ctmatch=&ctcreative={Creative}&ctcampaign=4660&ctkwd=&ctcreative=44622122499&ctplacement=&ctadpos=1o5&ctmatch=&ctlocid=9027618&cttrgtid=pla-294682000766&ctfeedid=&ctnwk=g&ctdevice=c If such a thing were to appear in an airplane, what breaker would you wire it to, assuming the original was removed and the breaker was used for the autopilot? Quote
Yetti Posted June 8, 2017 Report Posted June 8, 2017 in a 75 F model it is on the 10 amp breaker that shares the load with the ignition switch. A Greely hole punch is the fancy way to make a hole in the panel Quote
Yetti Posted June 8, 2017 Report Posted June 8, 2017 A metal holesaw is the white trash way of making the hole both involve drilling the greely will make less mess and won't risk messing up the panel finish Quote
Godfather Posted June 8, 2017 Report Posted June 8, 2017 38 minutes ago, Yetti said: in a 75 F model it is on the 10 amp breaker that shares the load with the ignition switch. A Greely hole punch is the fancy way to make a hole in the panel Have to say I'd run like the wind if an avionics shop quoted $55 (30 mins labor and a $5 car part). Quote
Yetti Posted June 8, 2017 Report Posted June 8, 2017 It is possible on a ramp check to get dinged for not having a cigarette lighter.since it was part of the original standard equipment Quote
N6758N Posted June 8, 2017 Report Posted June 8, 2017 14 hours ago, Godfather said: When I had my 327 upgraded to the 330es it took one guy a solid day with another person helping out on and off. I was at the shop and the installer was working hard and stayed after ~ an hour to finish the job. On a C model with the access panels up front, it should take no more than 6 hours to swap a new transponder in. In the OPS case he already has a 330 so there is no tray/rewiring to do. Just 2 wires added to the GPS source. Not sure if the OP has the 201 windshield or not which limits access, an Ovation on the other hand would take a bit longer... Quote
