Drumstick Posted June 5, 2017 Report Posted June 5, 2017 Is a lifting eye usually installed only while mounting a motor? I don't see one under my cowl. Which one is required for an M20c? Spruce is out of stock. We are looking to replace motor mounts and assembling the supplies. Quote
RLCarter Posted June 5, 2017 Report Posted June 5, 2017 It's under the dog house and it's a strap on the case center line bolt Quote
Drumstick Posted June 5, 2017 Author Report Posted June 5, 2017 2 hours ago, RLCarter said: It's under the dog house and it's a strap on the case center line bolt It should be visible from the front of the aircraft correct? - and I don't see one on mine. Quote
Mooneymite Posted June 5, 2017 Report Posted June 5, 2017 Not a great picture, but you can see the lifting eye just aft of the doghouse support..... Quote
Drumstick Posted June 5, 2017 Author Report Posted June 5, 2017 4 minutes ago, Mooneymite said: Not a great picture, but you can see the lifting eye just aft of the doghouse support..... Thanks - thats what I was looking for. 99% sure I don't have a lifting eye or doghouse support. Quote
1964-M20E Posted June 5, 2017 Report Posted June 5, 2017 is the dog house support good for lifting the engine? I'm sure it would work but the lifting eyes are usually thicker metal. Just wondering Quote
Mooneymite Posted June 5, 2017 Report Posted June 5, 2017 12 minutes ago, 1964-M20E said: is the dog house support good for lifting the engine? I'm sure it would work but the lifting eyes are usually thicker metal. I don't think it is strong enough. The doghouse support is just an aluminum strap....I think. Dropping an engine from the lift would be a bad thing. 1 Quote
Andy95W Posted June 6, 2017 Report Posted June 6, 2017 21 hours ago, Drumstick said: Thanks - thats what I was looking for. 99% sure I don't have a lifting eye or doghouse support. On my O-360, like yours, I don't have a lifting eye and I had to fabricate my own doghouse support. Quote
