Piloto Posted May 27, 2017 Report Posted May 27, 2017 (edited) My wife has taken over of the two seat back pockets for storing all kind of things. Water bottles, bible, relief pouches, napkins, candy and all the stuff that women carry in a purse. It leaves no room for the POH. Any suggestions for a good accessible place for the POH? José Edited May 27, 2017 by Piloto
carusoam Posted May 27, 2017 Report Posted May 27, 2017 I have an electronic copy of the Bible on the iPad. That may give enough room for the POH. I also have an electronic copy of the POH for easy reference. Nothing beats easy reference to E-procedures using the paper POH. So storing it too far away won't work... If your copilot can agree to an electronic copy of the Book, you may need another iPad for navigation apps. Thinking out loud, -a-
gsxrpilot Posted May 27, 2017 Report Posted May 27, 2017 The accessible copy on the iPad and the original on back on the hat rack. 3
gsengle Posted May 27, 2017 Report Posted May 27, 2017 I keep it in the passenger seat backSent from my iPhone using Tapatalk
Marauder Posted May 27, 2017 Report Posted May 27, 2017 My wife has taken over of the two seat back pockets for storing all kind of things. Water bottles, bible, relief pouches, napkins, candy and all the stuff that women carry in a purse. It leaves no room for the POH. Any suggestions for a good accessible place for the POH? José José - as you know I've got a fair amount of electronics in my plane and I ended up with a number of POH addendums and supplements. I think you are a Samsung user so I don't know if they have an equivalent of the iBooks on iOS. I keep all mine electronically. This has worked out well since they show up on all my I devices. Sent from my iPhone using Tapatalk Pro 1
Piloto Posted May 27, 2017 Author Report Posted May 27, 2017 7 minutes ago, Marauder said: José - as you know I've got a fair amount of electronics in my plane and I ended up with a number of POH addendums and supplements. I think you are a Samsung user so I don't know if they have an equivalent of the iBooks on iOS. I keep all mine electronically. This has worked out well since they show up on all my I devices. Sent from my iPhone using Tapatalk Pro Thanks but I am not that smart, I prefer paper. 1
Marauder Posted May 27, 2017 Report Posted May 27, 2017 Thanks but I am not that smart, I prefer paper. If I had to do paper, at last count I'm at 1,124 pages added to my POH. Sent from my iPhone using Tapatalk Pro 2
Piloto Posted May 28, 2017 Author Report Posted May 28, 2017 Went to the hangar today and found a good location for the POH. Underneath the pilot seat (2 knobs fully articulated) there is enough room for a shelve that will hold the POH. The shelve would be ty-wrapped to the front beam and rear axle. To make it easier to pull out the POH will be in a pouch with the strap in front so it can be pulled out easily. José 2
gsxrpilot Posted May 28, 2017 Report Posted May 28, 2017 41 minutes ago, Piloto said: Went to the hangar today and found a good location for the POH. Underneath the pilot seat (2 knobs fully articulated) there is enough room for a shelve that will hold the POH. The shelve would be ty-wrapped to the front beam and rear axle. To make it easier to pull out the POH will be in a pouch with the strap in front so it can be pulled out easily. I thought your relief tube was stowed under the pilot's seat? 1
peevee Posted May 28, 2017 Report Posted May 28, 2017 10 hours ago, carusoam said: I have an electronic copy of the Bible on the iPad. That may give enough room for the POH. I also have an electronic copy of the POH for easy reference. Nothing beats easy reference to E-procedures using the paper POH. So storing it too far away won't work... If your copilot can agree to an electronic copy of the Book, you may need another iPad for navigation apps. Thinking out loud, -a- How did you digitize it? I'd like to do the same but scanning one page at a time isn't how I'd like to do it.
Marauder Posted May 28, 2017 Report Posted May 28, 2017 How did you digitize it? I'd like to do the same but scanning one page at a time isn't how I'd like to do it. Most printers today have the ability to auto feed odd size documents. Sent from my iPhone using Tapatalk Pro
peevee Posted May 28, 2017 Report Posted May 28, 2017 Just now, Marauder said: Most printers today have the ability to auto feed odd size documents. Sent from my iPhone using Tapatalk Pro Mine does not or ability to duplex.
Marauder Posted May 28, 2017 Report Posted May 28, 2017 Mine does not or ability to duplex. The last two HP printers I have owned do it. Sent from my iPhone using Tapatalk Pro 2
Piloto Posted May 28, 2017 Author Report Posted May 28, 2017 33 minutes ago, gsxrpilot said: I thought your relief tube was stowed under the pilot's seat? The pilot relief hose coils itself onto the upper part of the seat structure with no interference. I already check it out. José 1
toto Posted May 28, 2017 Report Posted May 28, 2017 How did you digitize it? I'd like to do the same but scanning one page at a time isn't how I'd like to do it. I have an app called "Tiny Scanner" that I've used to create an electronic copy of a POH and other documents using the camera on my phone. Obviously not an auto-feed solution, but it's surprisingly useful, and accepts all different sorts of things that would be hard to scan. Tiny Scanner is available for both Android and iOS, don't recall whether it's free or cheap (but it's not particularly expensive in any case). 2
Hank Posted May 28, 2017 Report Posted May 28, 2017 Tiny Scanner was free when I downloaded it. Works pretty well.
L. Trotter Posted May 28, 2017 Report Posted May 28, 2017 Once scanned (PDF) the POH is about 100MB. How does one get this onto an IPAD?
RLCarter Posted May 28, 2017 Report Posted May 28, 2017 4 hours ago, L. Trotter said: Once scanned (PDF) the POH is about 100MB. How does one get this onto an IPAD? I have several documents in PDF form related to the aircraft on my iPad, I create the doc on a PC and convert it to a PDF then email to my self and open it on the iPad. Checklists, POH or any doc for that matter can then be opened within Wing-X, works well (foreflight has the same capabilities). 1
Marauder Posted May 28, 2017 Report Posted May 28, 2017 Once scanned (PDF) the POH is about 100MB. How does one get this onto an IPAD? If the POH addendum is available from the manufacturer, you can typically download them in PDF format. This makes it easy to store them in a central storage location (like Cloud iDrive, DropBox, Evernote or Microsoft One Drive). Sent from my iPhone using Tapatalk Pro
carusoam Posted May 29, 2017 Report Posted May 29, 2017 On 5/27/2017 at 9:49 PM, peevee said: How did you digitize it? I'd like to do the same but scanning one page at a time isn't how I'd like to do it. Scanner app, one click per page... Found a similar POH for easy reference away from the plane. An MSC had a few examples a while ago... BK has all their user manuals already scanned available on line... STC posted online.... I had a couple of things scanned automatically by a huge copier in the work environment. Best regards, -a-
Oldguy Posted May 30, 2017 Report Posted May 30, 2017 I have my POH and standard checklists scanned into my iPad and stored in ForeFlight. The one geeky thing I have is the POH has links in it to go to different chapters or back to the main index via a "click". One item I took away from the first Mooney Summit I went to a couple of years ago was Don Maxwell stating everyone should read their POH at least once a year to pick up something new about their plane. By having it in my iPad, I can browse it from time to time just to try to learn that one thing I had forgotten or never knew. 1
steingar Posted May 30, 2017 Report Posted May 30, 2017 I have a little pocket up front into which it fits nicely. But if you haven't one of those, I recommend a good strong pouch of some kind, and stash it under the pilots seat. That's what I find myself doing with the weight and balance.
gsxrpilot Posted June 1, 2017 Report Posted June 1, 2017 The POH for the 252 comes in a three ring binder over an inch thick. So it doesn't really fit in any of the pockets. I've scanned it, loaded it on the iPad and put the binder back in the hat rack.
Piloto Posted June 4, 2017 Author Report Posted June 4, 2017 Went on Saturday afternoon and did a storage shelve area underneath the seat. Cut a 7 1/2" x 15" a piece of .025 aluminum and bend down 1/2" forward for rivets and bend up 2" the rear for a barrier (keeps the POH from sliding back out0. It work out really well. The storage height depends on how high you set the seat. For mid position there is plenty of space for the POH and small tool bag. Took me about and hour but is worth it. José 1
