To the OP, my costs are as follows:
$2100 yr shade hangar
$900 yr insurance @ $55k
$1300 yr annual (basic), next annual will be more because I will elect to rework the rigging and probably put new pucks in.
Across almost 3 years of ownership, I have spent about $3k in unexpected maintenance.  During that same time frame, I spent about the same on expected maintenance.  (mostly magnetos)  I'm going to reevaluate engine reserve (unrealized cost) because lycoming just reduced prices a ton.. ;)  My guess is that some people will use that as rationale to buy more gizmos!  haha.
The amount of money I have spent on elective upgrades dwarfs everything else.  I have reworked my panel, added autopilot with altitude hold and other gizmos.. I'm not including those amounts here because they were elective.  Most costs are elective.  I spent less than $4k on fuel last year and flew 120 hours.
I think the overall difference between your 172 would be more dependent on what you WANT to do to your new mooney than what you would NEED to do..  my $0.02
Expand
Its just so hard to come up with numbers because it varies so much. I threw a rod a couple years ago. A fate far worse than an overhaul because I had no usable core. Before that, doing my own work etc my maintenance cost were less than my boat. But try to price an engine without a usable core, much, much more expensive than an overhaul and I only had 1000 hours since the engine was new from Lycoming (not reman, new).
-Robert
very true, which is why  I could only attest to what I have experienced thus far..   If mine comes up with an engine failure that results in an unusable core, I would be looking for a good used engine..
  On 3/13/2017 at 4:03 PM, Yetti said:
3 years is the replacement life cycle on corporate computer equipment....   lots of technology could change.
Yeah but FAA certification won't.
