Guitarmaster Posted July 12, 2016 Report Posted July 12, 2016 Ok, well... Need a pot. Potentiometer that is. Does anyone know the specs of the instrument lighting pot? The parts catalog and Google are suspiciously silent on the subject. I know rewiring a PWM would be the way to go, but the pot is easy and I already had the transistor panel out once... Not a job I want to do again. Sent from my iPad using Tapatalk https://goo.gl/photos/5qcquVcBGh1PyiKx5 Quote
Yetti Posted July 12, 2016 Report Posted July 12, 2016 Those pictures look like the diode bridge that sits on top of the wheel well Quote
Yetti Posted July 12, 2016 Report Posted July 12, 2016 http://www.digchip.com/datasheets/parts/datasheet/3883/2N3079-pdf.php just need to find a cross reference match Quote
Yetti Posted July 12, 2016 Report Posted July 12, 2016 Like the molex plugs for the bendix king radios may be out of luck Should be able to find an upgraded plate that would do the same thing. What does this do? Or like you said PWM for $15 is your friend. Searched via the case type T0-36 http://www.interfacebus.com/semiconductor-transistor-case-outlines-obsolete-jedec-types.html Quote
N201MKTurbo Posted July 12, 2016 Report Posted July 12, 2016 Do you need a pot or transistors? what is wrong? Have you checked the fuses? Quote
Guitarmaster Posted July 12, 2016 Author Report Posted July 12, 2016 Like the molex plugs for the bendix king radios may be out of luck Should be able to find an upgraded plate that would do the same thing. What does this do? Or like you said PWM for $15 is your friend. Searched via the case type T0-36 http://www.interfacebus.com/semiconductor-transistor-case-outlines-obsolete-jedec-types.html The pot acts as the base resistor for the transistor. I pulled the transistors and they tested fine, but I replaced them with new ones anyway since I had them out. Sent from my iPad using Tapatalk Quote
Guitarmaster Posted July 12, 2016 Author Report Posted July 12, 2016 Do you need a pot or transistors? what is wrong? Have you checked the fuses? I replaced the transistors. When operating at 12v, the lights will stay on and work fine. When 14v is coursing through the system, the lights work for a short time, begin to flicker then blow the 5A fuse. When i installed the PWM for the bezel lights, I was tired and shorted the circuit. The power for the PWM was being drawn from the hot side of the rheostat. When it shorted, it blew the fuse and the breaker. At that time, I thought I had damaged the transistor, but it tested ok. I replaced anyway since I had one. Upon further circuit analysis, I think the rheostat is damaged and internally shorts causing spikes in the light circuit thereby blowing the fuse. Sent from my iPad using Tapatalk Quote
DrBill Posted July 12, 2016 Report Posted July 12, 2016 Here's the circuit I got from one member. Measure one of them end to end.Then get it from Digikey or Mouser. If you need help computing the power, let me know. Bill Quote
DrBill Posted July 12, 2016 Report Posted July 12, 2016 lets see, its a 5A fuse, so with a power transistor and Beta of 10 means base current = 0.5A at full on. need 0.7 v on base at 0.5A so need to drop 12.9v at 0.5 a = 6.5 watts so a 10 watt pot would do. low end resistance = 12.9 / 0.5 = 25.8 ohms. High end should be about 10x that for full control or 250-300 ohms. I'd look for a 300 ohm , 10 watt pot in the size you need. I think that may be a challenge, 10 watts is pretty high for a pot like that. will not fit in package, have to see what is there.. must be 5 w or less. Bill here's a 5w 500 ohm pot for 5.34 http://www.digikey.com/product-detail/en/cts-electrocomponents/026TB32R501B1A1/CT2156-ND/203777 1 Quote
Guitarmaster Posted July 12, 2016 Author Report Posted July 12, 2016 lets see, its a 5A fuse, so with a power transistor and Beta of 10 means base current = 0.5A at full on. need 0.7 v on base at 0.5A so need to drop 12.9v at 0.5 a = 6.5 watts so a 10 watt pot would do. low end resistance = 12.9 / 0.5 = 25.8 ohms. High end should be about 10x that for full control or 250-300 ohms. I'd look for a 300 ohm , 10 watt pot in the size you need. I think that may be a challenge, 10 watts is pretty high for a pot like that. will not fit in package, have to see what is there.. must be 5 w or less. Bill here's a 5w 500 ohm pot for 5.34 http://www.digikey.com/product-detail/en/cts-electrocomponents/026TB32R501B1A1/CT2156-ND/203777 Awesome! Thanks! Sent from my XT1254 using Tapatalk Quote
DrBill Posted July 13, 2016 Report Posted July 13, 2016 if when you open it, measure the pot and R3 and R4 (if you have the two channel version) and I'll update the drawing for next time. Bill Quote
Guitarmaster Posted July 21, 2016 Author Report Posted July 21, 2016 I have had it with transistors and 50-year-old technology! In with the PWM's! The hanger elves removed the transistor panel altogether and rewired the system to work with PWM. Plugged it all in and....... NO MAGIC SMOKE! YES! It was actually a fairly easy job. All of the re-routing of connections was done on the transistor side of the cannon plug. Inline 5A fuses replaced the very expensive, hard-to-find and vulnerable GMW 5 fuses. Nice to have the instrument lights back. It's a big help at night. Side note: I have three, two of which are new, 2N2016 transistors for sale. Cheers! Quote
Guitarmaster Posted July 21, 2016 Author Report Posted July 21, 2016 On July 12, 2016 at 11:39 AM, daver328 said: Nice title. I thought, "This guy must live in Colorado or Washington?" Those new medical requirements for PPL sure are going to make this interesting!" I DID used to live in WA. In fact, I spent two years trying to kill myself in the weather, over the mountains in a Seneca2 and Chieftain every night. Ahhh, the days of building time. Quote
Yetti Posted July 21, 2016 Report Posted July 21, 2016 My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. 1 Quote
Guitarmaster Posted July 21, 2016 Author Report Posted July 21, 2016 Just now, Yetti said: My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Mine is the same. I, as well, have always found it interesting that there are still inline fuses. I suspect they are carryovers from earlier models. The inst light breakers are 10A and the inline fuse is 5A. The only thing I can come up with is they were there to protect the transistors from current spikes and the breaker is only there to handle a dead short condition. Now they protect the PWM from damage. Quote
Yetti Posted July 21, 2016 Report Posted July 21, 2016 Yea I have 2 -10 amp breakers for 3 pots. Some day need to trace it all out. Not sure a fuse is used for voltage spikes, the battery is supposed to take care of any spikes. That and the breaker on the field for the alternator. Quote
Marauder Posted July 21, 2016 Report Posted July 21, 2016 My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Just now, Yetti said: My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Mine is the same. I, as well, have always found it interesting that there are still inline fuses. I suspect they are carryovers from earlier models. The inst light breakers are 10A and the inline fuse is 5A. The only thing I can come up with is they were there to protect the transistors from current spikes and the breaker is only there to handle a dead short condition. Now they protect the PWM from damage. That was my 2013 project: Before: After: Sent from my iPad using Tapatalk Quote
ArtVandelay Posted July 21, 2016 Report Posted July 21, 2016 My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Just now, Yetti said: My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Mine is the same. I, as well, have always found it interesting that there are still inline fuses. I suspect they are carryovers from earlier models. The inst light breakers are 10A and the inline fuse is 5A. The only thing I can come up with is they were there to protect the transistors from current spikes and the breaker is only there to handle a dead short condition. Now they protect the PWM from damage. That was my 2013 project: Before: After: Sent from my iPad using Tapatalk Since you added a JPI afterwards, what did you do with your FF gauge? Quote
Marauder Posted July 21, 2016 Report Posted July 21, 2016 My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Just now, Yetti said: My F has what is basically a J panel with a pretty extensive circuit breaker panel.... It bothers me that there are still inline fuses behind the panel. One day I may have to fix that. Mine is the same. I, as well, have always found it interesting that there are still inline fuses. I suspect they are carryovers from earlier models. The inst light breakers are 10A and the inline fuse is 5A. The only thing I can come up with is they were there to protect the transistors from current spikes and the breaker is only there to handle a dead short condition. Now they protect the PWM from damage. That was my 2013 project:Before: After: Sent from my iPad using Tapatalk Since you added a JPI afterwards, what did you do with your FF gauge? Kept both. Sent from my iPad using Tapatalk Quote
Yetti Posted July 21, 2016 Report Posted July 21, 2016 What I don't get is 10 amps * 2 for instrument lights. is a lot of amps. What is an "ACU"? In a 170B the Com and Nav are actually separate sides of the radio which makes for good comm and nav circuit breakers segregation. In the KX155 the wiring could be separate but it is shown tied together at the radio. So why does do you still have the "Nav" circuit breakers? Should one not say GPS 1 and GPS 2 with all your fancy pants glass? Quote
Marauder Posted July 21, 2016 Report Posted July 21, 2016 What I don't get is 10 amps * 2 for instrument lights. is a lot of amps. What is an "ACU"? In a 170B the Com and Nav are actually separate sides of the radio which makes for good comm and nav circuit breakers segregation. In the KX155 the wiring could be separate but it is shown tied together at the radio. So why does do you still have the "Nav" circuit breakers? Should one not say GPS 1 and GPS 2 with all your fancy pants glass? I believe the two breakers were to cover the instrument brow & radio lights and the second breaker covered the annunciator and the overhead light. The ACU is the digital to analog controller for the Aspens. The reason there are two Nav are for the two Nav sides of the radios (GTN 650 and the GNC 255B). Sent from my iPad using Tapatalk Quote
Yetti Posted September 7, 2016 Report Posted September 7, 2016 A couple questions. Did you drill the rivets to remove the panel to get at the wiring? I am guessing co pilot side? Did you combine all three dimmers onto one PWM. What size PWM? 15 Amps seems like it would do it for all. Quote
air cooled dad Posted September 7, 2016 Report Posted September 7, 2016 On July 20, 2016 at 9:56 PM, Guitarmaster said: I DID used to live in WA. In fact, I spent two years trying to kill myself in the weather, over the mountains in a Seneca2 and Chieftain every night. Ahhh, the days of building time. Did you fly for Airpac??? Quote
Guitarmaster Posted September 7, 2016 Author Report Posted September 7, 2016 39 minutes ago, Yetti said: A couple questions. Did you drill the rivets to remove the panel to get at the wiring? I am guessing co pilot side? Did you combine all three dimmers onto one PWM. What size PWM? 15 Amps seems like it would do it for all. I didn't take the wheel well covers off. It was a major PITA to get the transistor panel out, but i was determined I was not taking that wheel well cover off again. If you have the quadrant, it is somewhat easier because you can see most of the screws. This is the PWM I used: https://amzn.com/B001CM74R2 I used two of them. One for the instrument lights and one for the radio lights. I didn't have a third pot... although it was on the schematic. They are 7A each and have built in protection. Something to note, with the transistors, there was considerable heat buildup. There is no or very little heat with the PWMs. They operate at ~100hz and there is no interference with the radios. Doing this mod requires you re-wire the transistor panel wiring coming from the cannon plug. If you were really ambitions, you could remove the cannon plug all together, but it was easier to to leave it. I was able to use all existing wiring, I just had to "repurpose" them. I made notes on what to do. I would be happy to send them to you, but yours may be different. Upon measuring the current draw, the instrument lights pull 3.5A and the radio lights 1.5A. With the PWM, I can now replace the power-hog, heat-monger incandescent lights with LED. Quote
Guitarmaster Posted September 7, 2016 Author Report Posted September 7, 2016 13 minutes ago, air cooled dad said: Did you fly for Airpac??? Yes I did... 1 Quote
