Gary0747 Posted May 27, 2016 Report Share Posted May 27, 2016 Are you supposed to use never-seize lube on the joints when putting stainless muffler connectons together? I wonder if copper or alluminum based never-seize lube will surface alloy with the muffler at high temperatures degrading the metal? Maybe best to assemble joints dry with no never-seize? Quote Link to comment Share on other sites More sharing options...
Bart Chilcott Posted May 27, 2016 Report Share Posted May 27, 2016 I just attended Don Maxwell's Mooney maintenance training in Texas and we covered this topic. He showed us how if the joints aren't lubed, the tubes will become dented from not being able to move. He recommends a lubricating/penetrating oil called "Mouse Milk" on the joints. 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted May 27, 2016 Report Share Posted May 27, 2016 Does this apply to the ball socket where the tail pipe attaches to the muffler? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 27, 2016 Report Share Posted May 27, 2016 I always use aluminum based anti-seize on slip joints. It makes them actually slip and you can disassemble them later. I've never seen any ill effects from the compound. I have seen ill effects from not using it. The ball joints don't need it. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted May 27, 2016 Report Share Posted May 27, 2016 PowerFlowSystems: All slip joints must be disassembled and lubricated with a high-temperature anti-seize compound (MIL-A-907E or equivalent) at 500hr or Annual intervals (whichever comes first). While disassembled, inspect for wear or galling. This should be performed more frequently if headers seize between inspections. Quote Link to comment Share on other sites More sharing options...
Shrobby Posted May 27, 2016 Report Share Posted May 27, 2016 Here is what Don Maxwell talked about.. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Shrobby Posted May 27, 2016 Report Share Posted May 27, 2016 Call him and buy some!! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Shrobby Posted May 27, 2016 Report Share Posted May 27, 2016 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yetti Posted May 27, 2016 Report Share Posted May 27, 2016 So once assembled with Mouse milk. Should you continue to apply at some interval? Quote Link to comment Share on other sites More sharing options...
cctsurf Posted May 27, 2016 Report Share Posted May 27, 2016 1 hour ago, Yetti said: So once assembled with Mouse milk. Should you continue to apply at some interval? Those who were just at the seminar can correct me, but I was told Essentially every time you open the cowl. Just a little. 2 Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted May 27, 2016 Author Report Share Posted May 27, 2016 (edited) Mouse milk is a common hydrocarbon based penetrating oil. I would think it will cook away at high temperature and not leave anything behind like the aluminum and copper based anti sieze compounds. I would think Mooney would give instructions on what to use in their manual, but I have never seen any. Edited May 28, 2016 by Gary0747 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted May 27, 2016 Report Share Posted May 27, 2016 Mouse milk is good for penetrating and helping get them apart but perhaps a copper based paste antiaircraft would be best for assembly Quote Link to comment Share on other sites More sharing options...
Guest Posted May 28, 2016 Report Share Posted May 28, 2016 I use some form of anti seize any time the pipes are apart, on slip joints and ball joints. In between I douce them with Mouse milk, seized pipes crack and break, free ones don't. Here's what Ram Aircraft recommends, http://www.ramaircraft.com/Maintenance-Tips/Sealless-Exhaust-Slip-Joints.htm Clarence Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted May 28, 2016 Author Report Share Posted May 28, 2016 This Ram recommendation makes the most sense to me. They are recommending a Nickel based anti seize paste. This is more expensive than copper and aluminum based anti seize but does not run the risk of surface alloying a lesser metal and degrading the stainless. Quote Link to comment Share on other sites More sharing options...
