Looking for some recommendations for tires.  Going to change all 3.  The choice is between Michelin Air v. Goodyear Flight Custom III.
I live in New England so I will see some ice and snow if that makes a difference.  6.00 X 6  6 ply for mains and 5.00 X 5, 6 ply for nose.
Also, look at air stop tubes.  Any experiences?
Any tire recommendations?   Please state reasons why you prefer one over another.
Thanks,
John Breda
Can't speak to Goodyear, but I have had excellent experience with Dresser retreads.  Perfectly good tires at a fraction of the price of new ones.  My mechanic won't put on anything else.
Goodyear flt 3's with the michilen airstop tubes!
However, our airplanes are so light the tires will probably Dry rot before they ware out.
I personaly have Condors on mine. 6 years 300hrs, no noticeable ware on the mains. Slightly scalloped nose tire from the torque on take off. Might upgrade to a better nose tire. Maybe a used Goodyear. Lol.
For good looks and spending coin, Goodyear Flight Custome 3's.
-Matt
My MSC is the opposite, wont do retreads, I put on Condors which weren't that more expensive
Lots of tires will do fine.  However, as Matt said, only Airstop tubes.  They truly do eliminate or cut  adding air to near zero.
You will not regret retreads from Desser. Good reviews. Have put them on a Bonanza, C310, Citabria, and now on my "C". No problems.
I know the topic was on tires, .... but I would second the MICHELIN AIRSTOP® TUBES.  My experience is that the hold air much better than Goodyear tubes I have had on previously .
James '67C
I have owned my vintage short-body for 14 years.  I listened to Aviation Consumer and put Air Hawk Tires on (Mains and nose gear).  I have had zero issues with the tires.  ZERO.  I put expensive rubber on my Sports Car and SUV.  My Mooney?  Not so much...and I couldn't be happier with my decision.
I don't think you can go wrong with any approved tire that's TSO'd. They're all excellent tough tires.
The difference imo is how convincing is a certain manufacturer's marketing pitch that they have exceeded TSO and to what level. This may be important to some and it may be false economy to others. It's a matter of personal preference.
The more important thing I think is to be sure to use a high quality tube and keep very close tabs on tire pressures.
Here's a question: Anyone know if retreads are TSO'd?
