ryoder Posted January 19, 2015 Report Posted January 19, 2015 My windshield has to go. It's a 65C and I want to get a normal one piece not a 201. Who has the lowest price? Is it LP Aero? Should I get the thickest there is because I want low cabin noise but don't want my mechanic to tell me it's another five hours labor to put a thick one in. Which color should I get if I am not switching out the others? The others have some kind of slight tint to them but I can't put my finger on it. It could be an optical illusion but the side windows seem to look greenish blue. Going to order this stuff today and hopefully drop the plane off to get tanks sealed and this scheduled.
Guest Posted January 19, 2015 Report Posted January 19, 2015 LP Aero or Great Lakes Aero Plastics are two choices, both are fine. Remember that thicker is better considering that you will be removing the centre metal structure(not the steel tube) Solar gray is a nice colour, but may clash with your side windows, unless you plan to replace them in time. Clarence
N601RX Posted January 19, 2015 Report Posted January 19, 2015 I used 1/4 solar grey all the way around. The amount of tint is just right. It helps in the daytime, but isn't dark enough cause problems at night.
ryoder Posted January 19, 2015 Author Report Posted January 19, 2015 Is the stock window tinted at all? I don't want to replace the other windows at this time and probably won't replace them for some time so which color should I get?
carusoam Posted January 19, 2015 Report Posted January 19, 2015 It is easier to tell if the light was shining on a white piece of paper instead of the black rubber anti-slip surface... The color is more observable if you can get acces to the edge of the window... If they are original, they are coke bottle green... Which is green but not neon or fluorescent green... Best regards, -a-
Marauder Posted January 19, 2015 Report Posted January 19, 2015 Is my glass green? I don't know what color your glass is, but our planes could be twins!
ryoder Posted January 19, 2015 Author Report Posted January 19, 2015 The pilot window closer thing has a bit of a green tint. They are original but just dont have a whole lot of tint. If I buy only the windshield I will probably have to go with clear if I dont want green right? I am not a fan of blatantly green windows. Marauder they do look a bit similar but you have a nicer one with more modern looks.
DonMuncy Posted January 19, 2015 Report Posted January 19, 2015 I changed my windshield to the smoke color. After I got it in, my wife informed me it didn't look right with the green side windows. I did not know they were green. I changed them to smoke also and now it looks great. 2
carusoam Posted January 19, 2015 Report Posted January 19, 2015 From experience... I was changing out the door window... Couldn't tell it was green... Bought clear because it sounds like a good idea.... Installed window... Wife baked like a cake in the copilot window. Easy to swap for a matching green one... Same experiment can be done at a lower cost with the pilot's vent window... Take a look at the edges of the vent window and the pilot's side window. Best regards, -a- It turns out our car windows are nicely shaded for a reason... Ever sit in the back seat of a 60’s family car?
DrBill Posted January 19, 2015 Report Posted January 19, 2015 Mine is green tint and it messes up pictures taken through it. If I had to do it again I'd go clear. Bill
ryoder Posted January 19, 2015 Author Report Posted January 19, 2015 I am beginning to think its green. I'll go with green as long as its the same level of green as the original windows. The other windows are in great shape and I don't want to be forced into an upgrade for no good reason. Is the new windshield going to look very very green compared to the older windows that might have lost some green over the years?
carusoam Posted January 20, 2015 Report Posted January 20, 2015 The colors seem to be set at the sheet factory with some tight specifications... When I replaced the door window it didn't appear to be different in color compared to the other ones... Just clear with no scratches... Surprising how they don't change over time...accept on the surface. Best regards, -a- 1
ryoder Posted January 20, 2015 Author Report Posted January 20, 2015 Thanks. The green windshield it is. The Mooney goes under the knife next Monday for a reseal and I'll see about getting the windshield going concurrently. Going to order from LP Aero tomorrow!
piperpainter Posted January 20, 2015 Report Posted January 20, 2015 Don't do GREEN!!! They don't look nearly as good as the Smoke or clear! Just saying
ArtVandelay Posted January 20, 2015 Report Posted January 20, 2015 Don't do GREEN!!! They don't look nearly as good as the Smoke or clear! Just saying Depends, on a plane with green paint I think it would look nice 1
ryoder Posted January 20, 2015 Author Report Posted January 20, 2015 I like how the glass looks now. Can't even tell its green. Can you from the pic?
N601RX Posted January 20, 2015 Report Posted January 20, 2015 If you can't tell the side windows are green then consider the smoke gray for front one.
carusoam Posted January 20, 2015 Report Posted January 20, 2015 Windshield color is the most important decision... The other windows are easy to swap out if you were to change your mind... The lighter tint of gray seems to be what new planes were using. Texas, might go with the darker gray... Best regards, -a-
bonal Posted January 20, 2015 Report Posted January 20, 2015 Whenever I have seen Mooney's with the green tint it's very obviously green and looking at you pics not so sure yours are as well. Just my 2 pennies worth I would go clear on the wind screen I like to have the "clearest view possible" you can always where shades or put down the visors which in my case are smoked.
ryoder Posted January 20, 2015 Author Report Posted January 20, 2015 So now I am worried and think I should just order clear. That way I can get tinted side windows later on and a clear windshield should look fine if I have light green side windows.
ArtVandelay Posted January 20, 2015 Report Posted January 20, 2015 You can add tint to cars windows, can you do the same for planes? Sent from my iPhone using Tapatalk
N601RX Posted January 20, 2015 Report Posted January 20, 2015 Here is a green one on a white towel. See how yours look on a white background. 3
TTaylor Posted January 20, 2015 Report Posted January 20, 2015 Go with the SC Gray, you will be glad you did. Clear just makes it too bright and hot. SC Gray is good in daylight and not too dark for night. The SC Gray will also reduce sun damage to your interior. You will want to change the side windows out someday so you might as well start the process by doing the windshield in the correct tint now. 1
