AndyFromCB Posted January 16, 2015 Report Share Posted January 16, 2015 Does anyone know the part number for the blade VOR/LOC antennas on vertical tail for a steam gauge Mooney Bravo. Mine appears to be cracked... Quote Link to comment Share on other sites More sharing options...
spaz Posted January 16, 2015 Report Share Posted January 16, 2015 is it COMANT VOR/LOC/GS (CI-120-400)? Quote Link to comment Share on other sites More sharing options...
AndyFromCB Posted January 16, 2015 Author Report Share Posted January 16, 2015 is it COMANT VOR/LOC/GS (CI-120-400)? Looks like it. I wanted to order one before taking the old one off. Getting ready to sell the Bravo and don't want any squawks to deal with at sale. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted January 16, 2015 Report Share Posted January 16, 2015 Here's some pic. ASpruce should be pretty competitive: http://www.aircraftspruce.com/menus/av/antenna_vornav.html Your aircraft log book should have a record of what's on the plane now. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 16, 2015 Report Share Posted January 16, 2015 I think sky geek sells individual blades. You need to remove one and see what exact model it is. Many models if the ci-120 but some are shaped a little different and you'll be able to tell. Quote Link to comment Share on other sites More sharing options...
AndyFromCB Posted January 16, 2015 Author Report Share Posted January 16, 2015 I think sky geek sells individual blades. You need to remove one and see what exact model it is. Many models if the ci-120 but some are shaped a little different and you'll be able to tell. I guess I'll drag my ass out tomorrow, take the plane for a spin and then take off the antenna and look up the part number. I guess I better bring a ladder. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted January 16, 2015 Report Share Posted January 16, 2015 I guess I'll drag my ass out tomorrow, take the plane for a spin and then take off the antenna and look up the part number. I guess I better bring a ladder. Is it still working? Looks like the new one is 1.2 AMU+. Just saying... Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 16, 2015 Report Share Posted January 16, 2015 Single blade this style is 500$ http://m.skygeek.com/comant-ci-120-1-one-blade-antenna-ci-120-g-s.html However, u can fix cracks with epoxy and finish with epoxy and micro. Quote Link to comment Share on other sites More sharing options...
AndyFromCB Posted January 16, 2015 Author Report Share Posted January 16, 2015 Single blade this style is 500$ http://m.skygeek.com/comant-ci-120-1-one-blade-antenna-ci-120-g-s.html However, u can fix cracks with epoxy and finish with epoxy and micro. Can you, my mechanic, who is generally pretty cool about lots of things, is not a fan of doing that claiming that since they cannot even be painted, epoxy is out of question. What is micro? Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 16, 2015 Report Share Posted January 16, 2015 Microbaloons, microscopic glass spheres, made to fill without weight. It looks like blow. Add to epoxy make a cake batter style filler. Easy to sand. So, clean crack, repair with aircraft grade epoxy such as MGS, but I suppose West Systems will do it. No Devcon hardware store epoxy. And for sure no "boat fiberglass repair" which is almost always polyester resin, and is garbage in this application. Airplane epoxy. fill the crack to just below the surface. Then mix up some microbaloons and epoxy to make filler, fill the crack. sand it down level, its only cosmetic. You have to paint it with a TiO2 free paint, such as a BMS 10-60 Type II conforming paint, such as Eclipse ECL-G-10, Skygeek used to stock it, it was 35$ for a kit. mix that up, and apply with a brush only to the repair and sparingly. If you want to get anal, airbrush it to blend the repair and hide it. here's Boeing's take: http://aircraft-support.blogspot.com/2009/09/boeing-aircraft-paint-spec.html Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted January 16, 2015 Report Share Posted January 16, 2015 I'm constantly amazed at how Byron knows these things. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 16, 2015 Report Share Posted January 16, 2015 With deep and appropriate detail... -a- Quote Link to comment Share on other sites More sharing options...
AndyFromCB Posted January 16, 2015 Author Report Share Posted January 16, 2015 Microbaloons, microscopic glass spheres, made to fill without weight. It looks like blow. Add to epoxy make a cake batter style filler. Easy to sand. So, clean crack, repair with aircraft grade epoxy such as MGS, but I suppose West Systems will do it. No Devcon hardware store epoxy. And for sure no "boat fiberglass repair" which is almost always polyester resin, and is garbage in this application. Airplane epoxy. fill the crack to just below the surface. Then mix up some microbaloons and epoxy to make filler, fill the crack. sand it down level, its only cosmetic. You have to paint it with a TiO2 free paint, such as a BMS 10-60 Type II conforming paint, such as Eclipse ECL-G-10, Skygeek used to stock it, it was 35$ for a kit. mix that up, and apply with a brush only to the repair and sparingly. If you want to get anal, airbrush it to blend the repair and hide it. here's Boeing's take: http://aircraft-support.blogspot.com/2009/09/boeing-aircraft-paint-spec.html Very much appreciated. Thanks. I'm not going to ask why you know what blow looks like…Scarface I assume... Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted January 16, 2015 Report Share Posted January 16, 2015 My post had nothing to do with the "blow" aspect. It was a compliment about breadth of knowledge. Quote Link to comment Share on other sites More sharing options...
