The-sky-captain Posted January 15, 2009 Report Posted January 15, 2009 What are you guys thoughts on the Mooney ram air system? I've got a 77 J and notice only about a 1/2" or so when it is on so I generally don't use it. I don't really see any difference with it on or off.
KSMooniac Posted January 15, 2009 Report Posted January 15, 2009 I see no measurable difference on my '77 J and never use it. In fact it was completely deleted on the later model J's and there is a kit available to do so for our planes. As I found out a few weeks ago, the deletion kit is *much* cheaper than the rubber seal between the ram air ring and the cowl! Before I paint my plane I will either apply the kit (needs to be painted after installation) or switch to a LoPresti cowl that retains ram air and makes it effective. The Pre-J planes I flew (a couple F's and and E) it was good for a solid 1" of MP when used, though.
Rustler Posted January 15, 2009 Report Posted January 15, 2009 I've got a new-to-me '80 J and see little or no difference opening the ram air. I don't bother to use it. I'm about to make a trio from Texas to South Carolina and Tennessee and intend to use some of the idle time to try to determine whether it is my imagination or not.
The-sky-captain Posted January 15, 2009 Author Report Posted January 15, 2009 The flush plug does sound like it would be an easy fix to the problem. Wonder why there isn't a mod out there for it?
GeorgePerry Posted January 16, 2009 Report Posted January 16, 2009 I guess I'm the exception but I get a full 1 in of MP boost with it on. Also a noticable change in EGTs between open and closed. I use it, for what that's worth, I HATE MICROSOFT!!!! The sooner the world embraces MAC's the better. Sorry for the tripple post
Cruiser Posted January 16, 2009 Report Posted January 16, 2009 the biggest thing I noticed about Ram air was the annunciator light kept coming on during short final. It was very irritating. Had to have the cable adjusted. I have used it without any noticeable improvements.
Piloto Posted January 18, 2009 Report Posted January 18, 2009 Although not very effective it can be useful for determining air filter replacement. If you get more than 1/2" difference on MP it is time to replace the air filter. José
m20j Posted January 20, 2009 Report Posted January 20, 2009 With a digital MP gage on a '77 201, it is good for .2 to .3 inches with a corresponding increase in fuel burn. I can't see the analog gage move at all. I use it at altitude on long flights for a little extra oomph, but not for short hops.
hansel Posted November 27, 2009 Report Posted November 27, 2009 We had the ram closure kit on our '79 J at purchase but the cowling fiberglass work was never completed. The lower cowl had some unrelated heat damage develop over the years that we recently decided to fix, so it seemed like the right time to finally plug the blow hole. A pretty painless process overall (about $700). Pics attached. I'm expecting improved aerodynamics to add at least 10mph to my airspeed (j/k)
The-sky-captain Posted November 27, 2009 Author Report Posted November 27, 2009 Quote: KSMooniac I see no measurable difference on my '77 J and never use it. In fact it was completely deleted on the later model J's and there is a kit available to do so for our planes. As I found out a few weeks ago, the deletion kit is *much* cheaper than the rubber seal between the ram air ring and the cowl! Before I paint my plane I will either apply the kit (needs to be painted after installation) or switch to a LoPresti cowl that retains ram air and makes it effective. The Pre-J planes I flew (a couple F's and and E) it was good for a solid 1" of MP when used, though.
Immelman Posted November 27, 2009 Report Posted November 27, 2009 Ram air makes a solid 1" rise in MP on my E model, and a notiable performance boost. Anytime I'm going someplace (not a local 'slow' flight) its on as long as the atmosphere permits, until descent.
Piloto Posted November 29, 2009 Report Posted November 29, 2009 Hansel your ram air mod looks beautiful and professional. You probably get more speed now (less drag) than when it was used before. Thanks for the pictures José
KSMooniac Posted November 30, 2009 Report Posted November 30, 2009 Bodie, yes I deleted my ram air system when I had the plane painted. The shop filled in the cowling hole prior to paint, so it looks like it was never there. Back home, I removed the rest of the system and riveted a close-out panel onto the induction box where the ram air intake used to reside. Simple task, but it took a long time to R&R everything since the air box had to come off the plane to rivet the plate with regular "smash" rivets. Apparently you're not supposed to use blind rivets on induction components. Removing the ram air cable + microswitch assy was a PITA due to tight access under the panel, as usual.
231Pilot Posted December 29, 2009 Report Posted December 29, 2009 I do not use it. Bugs and other junk can be found in the air at RAM AIR altitudes. Not a good thing. I want clean, filtered air going into my precious bird.
rogerl Posted March 28, 2010 Report Posted March 28, 2010 Spent the last few days at Doña Ana (5T6) - a couple more than planned. Friday 55/60 mph wind/sand storm popped up, and by the time we got to the airport, conditions were too bad to move zt from the tiedown into the hanger. Fortunately for the structure - but unfortunately for the ram air door - it was pointed into the wind. The ram air door doesn't close super tightly - even though the gasket is reasonably pliable. Sand/dust had an hour or so to infiltrate before we got to it to duct tape over the door. Saturday was spent removing the cowling and the ram air butterfly valve and carefully sponging out debris. Fortunate that the throttle was fully closed, leaving that horizontal butteryfly valve as a further obstacle to ingress. The return trip Sunday was uneventful, so seems that any damage is more chronic than acute. An A&P/IA that was around did note that he wouldn't worry about it, as most would blow through the engine at startup - but I did my best to get every speck I could find out, + am going to do an oil and filter change ASAP. Lessons learned: 1) Hanger it if there's a reasonable option; or at least be vigilant about the weather when on a trip even while NOT flying 2) Cover and delete the ram air system ASAP Side note: 5T6 FBO operator "Blue Feather Aviation" took great care of us - I highly recommend paying a visit if you have a chance. Don't miss war eagles air museum (http://www.war-eagles-air-museum.com) on the field.
kallend Posted March 29, 2010 Report Posted March 29, 2010 Quote: KSMooniac The Pre-J planes I flew (a couple F's and and E) it was good for a solid 1" of MP when used, though.
Stefanovm Posted May 15, 2010 Report Posted May 15, 2010 I have a slightly different problem with my ram air. When I picked my 65 E model up two months ago, I noticed that the flap was not closed. Every time I tried to close it the cable housing just backed out of the last clamp. Therefore, I do not use it. It does not seem to come open if I do not touch the control and have forced it closed (left photo). However, if I open it with the control (right photo), I have to close it later by removing the side cowling and forcing the outer cable and actuator arm to move forward. This is very hard to do in the tight conditions. I took photos through oil cooler opening. I tried to see if I could find a better way to anchor the outer cable and the oil cooler is not normally out of the way when I force it closed in very tight conditions. My A&P did not seem to know what would be an "official" repair. I know it needs work. Any suggestions for central Texas? San Marcos probably. The door gasket also appears to be in pretty bad shape and should also be replaced. I am sure stuff that should not be getiing into the system may be doing so around the gasket. It does stay in a hanger, but I fly from a grass strip. Infiltration worries me. I wonder if it is not staying closed even though the control is firmly against the panel. However, when back on the ground it seems closed by looking unless I have accidentally pulled the control after the last hand closure from the engine compartment. Again it also needs a new gasket or door. I am contemplating a temporary plug using expaning foam.
scottfromiowa Posted May 15, 2010 Report Posted May 15, 2010 I use my Ram Air ALL THE TIME IN CRUISE, unless down low where I am not at full throttle and get 25 inches without the Ram-Air. I get a nice boost on my '66 E. Make sure the gasket is functional and don't open down low or in moisture. End of story. The lite is a nice reminder...as well as my decent checklist...I have no fear of a phantom grasshopper at 7500 feet.
Mooney65E Posted May 16, 2010 Report Posted May 16, 2010 I use mine over 5000' in clear air only and see 1" plus MP increase. Take very good care of the boot which connects the door to the cowling during removal of lower cowling. They are EXPENSIVE!
Ned Gravel Posted May 16, 2010 Report Posted May 16, 2010 Quote: Mooney65E I use mine over 5000' in clear air only and see 1" plus MP increase. Take very good care of the boot which connects the door to the cowling during removal of lower cowling. They are EXPENSIVE!
Mcstealth Posted May 17, 2010 Report Posted May 17, 2010 Quote: Stefanovm I have a slightly different problem with my ram air. When I picked my 65 E model up two months ago, I noticed that the flap was not closed. Every time I tried to close it the cable housing just backed out of the last clamp. Therefore, I do not use it. It does not seem to come open if I do not touch the control and have forced it closed (left photo). However, if I open it with the control (right photo), I have to close it later by removing the side cowling and forcing the outer cable and actuator arm to move forward. This is very hard to do in the tight conditions. I took photos through oil cooler opening. I tried to see if I could find a better way to anchor the outer cable and the oil cooler is not normally out of the way when I force it closed in very tight conditions. My A&P did not seem to know what would be an "official" repair. I know it needs work. Any suggestions for central Texas? San Marcos probably. The door gasket also appears to be in pretty bad shape and should also be replaced. I am sure stuff that should not be getiing into the system may be doing so around the gasket. It does stay in a hanger, but I fly from a grass strip. Infiltration worries me. I wonder if it is not staying closed even though the control is firmly against the panel. However, when back on the ground it seems closed by looking unless I have accidentally pulled the control after the last hand closure from the engine compartment. Again it also needs a new gasket or door. I am contemplating a temporary plug using expaning foam.
N201MKTurbo Posted May 18, 2010 Report Posted May 18, 2010 Stefanovm You should not use a cushoned clamp for the cable. You will never get it stop slipping. Rig the cable about 1/4 inch through the clamp, then wrap about two turns of lock wire around the end of the cable sheath, twist it tight for the length of the clamp then wrap a few more turns around the cable on the other side of the clamp and twist the loose ends. Another option would be to get some of the boden cable nuts that are used on the Mooneys with the Dukes gear actuator for the emergency engagement cable and put two nuts on either side of the cable.
N201MKTurbo Posted May 18, 2010 Report Posted May 18, 2010 Stefanovm You are also missing a clamp. There should be a second clanp held on by a spacer and bolt that goes through the empty hole in the middle of your second photo.
