Aron Peterson Posted January 26, 2014 Report Share Posted January 26, 2014 I am in need of a new engine. I am thinking of a factory reman or new. But who to put it on is the real problem. I would appreciate any feedback on this subject. Thank you Quote Link to comment Share on other sites More sharing options...
triple8s Posted January 26, 2014 Report Share Posted January 26, 2014 I have a buddy who's turbo arrow went tits up he sent his TCM TSIO 360 to Zephyr Hills in Florida. He doesn't have it back yet so can't say yet how they did. I had a Poplar Grove rebuild and it was a very good engine but it was a Lyc not TCM. Quote Link to comment Share on other sites More sharing options...
quik flite Posted January 26, 2014 Report Share Posted January 26, 2014 You should find a Mooney Service Center in your area and have them do it , it may not be rocket science but there are a lot of little things to do properly the first time , it may save you more than just money .Did you take some pictures when you removed it? That would help. 1 Quote Link to comment Share on other sites More sharing options...
Aron Peterson Posted January 26, 2014 Author Report Share Posted January 26, 2014 Really good idea to take pics. I would like to hear about Poplar Grove when he gets it back. I do want it done right. Would like to have this machine for a while. I don't mind spending the money. My family and my butt will be at stake. Aron Quote Link to comment Share on other sites More sharing options...
Aron Peterson Posted January 26, 2014 Author Report Share Posted January 26, 2014 Anybody hear how Don Maxwell does? Quote Link to comment Share on other sites More sharing options...
quik flite Posted January 26, 2014 Report Share Posted January 26, 2014 I always used Webers a Mooney Service Center  at KLNS in PA with excellent results , but have heard great things about Maxwell and he is always helpful and knowledgeable and takes time to answer questions on Mooneylist. Quote Link to comment Share on other sites More sharing options...
quik flite Posted January 26, 2014 Report Share Posted January 26, 2014 That is the Mapalist ,not Mooneylist , that Maxwell is on frequently. You can sign up and get emails of the questions daily. Or give him a call. Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted January 26, 2014 Report Share Posted January 26, 2014 Don Maxwell is top notch! Don uses Robert at Mena Aircraft engines...............also a top notch and highly rated engine builder. Quote Link to comment Share on other sites More sharing options...
Aron Peterson Posted January 27, 2014 Author Report Share Posted January 27, 2014 Thank you all for your replies. Aron Quote Link to comment Share on other sites More sharing options...
jlunseth Posted January 27, 2014 Report Share Posted January 27, 2014 Willmar has had my engine on and off a couple of times and done a nice job. No complaints. Quote Link to comment Share on other sites More sharing options...
aaronk25 Posted January 28, 2014 Report Share Posted January 28, 2014 Willmar has had my engine on and off a couple of times and done a nice job. No complaints. How long ago was it that you worked with Willmar, my experience has been terrible but that is just in the past 2 years ever since Brian Negan bought it from Bruce Jagger. Bruce ran a top notch shop and the jokers that run it now can't even time a mag to spec or fill logs out or complete logs or actually accurately complete a log book entry (prop governor logged as overhauled, never serviced) alternator about fell off as nut was laying in cowl, severed ILS cable routed it though controls, didn't hook up tail light. Just flat terrible experience. Go anywhere but Willmar, except to see paul at weep no more he is great! Quote Link to comment Share on other sites More sharing options...
Nemesis Posted January 28, 2014 Report Share Posted January 28, 2014 The LB engine in my K was done by Poplar Grove by the previous owners. It has over 1400 hours on it and still going strong. The logs do not show any engine work after it was installed except timing and oil changes - no cylinders ever removed. My lowest compression at last annual was 65 but that does not bother me. I probably won't mess with that cylinder until in the lower 50s unless there is some over riding reason to do so like a bad borescope photo or rising oil consumption. If I remember right, low compression by TCM specs is 45 or so. It uses only between 0 and 1/2 quart for 25 hours. Seriously, I never add oil between changes. I will likely send the same engine back to them when the time comes. Â Dave Quote Link to comment Share on other sites More sharing options...
Aron Peterson Posted January 29, 2014 Author Report Share Posted January 29, 2014 Thank you, Â Aron Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted January 29, 2014 Report Share Posted January 29, 2014 Poplar Grove has an outstanding reputation from everything I've read. Â Maxwell would be a great choice as well, but not close to you. Â R&R'ing the engine isn't terribly challenging IMO, or at least removing it! Â Â I just took mine off and it was straightforward...I took pics and labeled some wires. Â There isn't a lot to it. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 29, 2014 Report Share Posted January 29, 2014 It took me 8 days to install it working mostly by myself (it takes two to line up the engine mounts). I also replaced all the hoses with the integral fire sleeve type which requires all new Adel clamps due to the different OD of the hoses. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted January 29, 2014 Report Share Posted January 29, 2014 Byron, where did you get your hoses? Â I'm debating that right now...mine were replaced shortly before i bought it and have life left, but I'm usually susceptible to "while you're in there..." Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 30, 2014 Report Share Posted January 30, 2014 Precision hose technology in Tulsa. I got the brown 124J hoses Quote Link to comment Share on other sites More sharing options...
triple8s Posted January 31, 2014 Report Share Posted January 31, 2014 I can't emphasize the importance of replacing hoses atleast every five years. At the first annual my mechanic said mine looked old and felt hard and should be replaced, I thought awwww they'll last a bit longer but didn't say it and went with what I was told. Now today six years later I have seen three instances where folks have had oil hoses fail and it's an expensive proposition that involves a non simulated engine failure. Replace the hoses it is cheap insurance, they will break! Quote Link to comment Share on other sites More sharing options...
jetdriven Posted January 31, 2014 Report Share Posted January 31, 2014 Triple8s were they Teflon hoses? I haven't heard of a failure of those. The Mooney SMM says rubber hoses get replaced on a 12 year cycle but for Teflon it says "on condition". The Teflon hoses even take a permanent set as described in AC43.13 but if you don't kink them while disturbing them that they are still serviceable. Quote Link to comment Share on other sites More sharing options...
triple8s Posted January 31, 2014 Report Share Posted January 31, 2014 One failure was a Teflon hose the others were not. The Teflon hoses went to a waste gate controller and dumped all but 2 qts on a TSIO 520. Won't be cheap I bet. I may get pics this weekend, I have been hauling a plump aircraft mechanic to the stricken bird. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 24, 2017 Report Share Posted January 24, 2017 On 1/25/2014 at 8:32 PM, Aron Peterson said: I am in need of a new engine. I am thinking of a factory reman or new. But who to put it on is the real problem. I would appreciate any feedback on this subject. Thank you Who did you end up using to install your SB engine? Quote Link to comment Share on other sites More sharing options...
Aron Peterson Posted January 24, 2017 Author Report Share Posted January 24, 2017 Who did you end up using to install your SB engine? I had Max D put it on. I heard the folks down at Premier at FXE do a great job and are very professional. Ray B is the guy to talk to.I ended up getting a factory new. I plan to have it for a while and wanted a known quantity. Aron 1 Quote Link to comment Share on other sites More sharing options...
thinwing Posted February 2, 2017 Report Share Posted February 2, 2017 Nice but it is on a bonanza Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted February 3, 2017 Report Share Posted February 3, 2017 Aron, I had my factory reman IO550N installed two years ago, and couldn't be happier. Â CMI (TCM at that time) shipped the engine to my mechanic in TX, and I flew down for annual. Â During this "extended annual", we removed old engine and prop, installed the new engine, sold the old prop, shipped the old engine core back to CMI, and the costs were exactly what CMI and my mechanic quoted, so the budget stayed intact. Â All in all, a wonderful experience. Depending on where you choose to get your engine, they could ship to Don if that's who you choose. Â Not sure if you're a proponent of user-assisted annuals and maintenance (or if Don's shop allows that), but if so, you may want to factor that into your decision-making when looking for a shop. Â I've only gone through this twice (user-assisted both times), but you're welcome to PM if you have additional questions. Steve Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted February 3, 2017 Report Share Posted February 3, 2017 1 hour ago, StevenL757 said: Aron, I had my factory reman IO550N installed two years ago, and couldn't be happier. Â CMI (TCM at that time) shipped the engine to my mechanic in TX, and I flew down for annual. Â During this "extended annual", we removed old engine and prop, installed the new engine, sold the old prop, shipped the old engine core back to CMI, and the costs were exactly what CMI and my mechanic quoted, so the budget stayed intact. Â All in all, a wonderful experience. Depending on where you choose to get your engine, they could ship to Don if that's who you choose. Â Not sure if you're a proponent of user-assisted annuals and maintenance (or if Don's shop allows that), but if so, you may want to factor that into your decision-making when looking for a shop. Â I've only gone through this twice (user-assisted both times), but you're welcome to PM if you have additional questions. Steve I think he had it installed with Don Maxwell a couple of years ago. Quote Link to comment Share on other sites More sharing options...
