Oscar Avalle Posted November 15, 2013 Report Share Posted November 15, 2013 Since about two flights I have been hearing a strange noise when I retract the landing gear (electric). I looked at the front wheel and it seems that it touches the landing gear compartment while it retracts. Any suggestions of what may be going on... How can I adjust the front wheel? Quote Link to comment Share on other sites More sharing options...
isaacpr7 Posted November 15, 2013 Report Share Posted November 15, 2013 Check the mooney.com site. I saw either a sevice bulletin or service instruction that deals with this a few days ago. Has your nose gear been modified so it has no play upon landing? The additional spacer that is put in play to fix this problem can cause what you are experiencing but the other SB or SI covers how to fix this. Another thing that might help in the mean time is pressing the brakes while airborne, prior to retracting the gear. This will stop the rolling motion of the tires before they are stored, thus eliminating any rubbing noise. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 15, 2013 Report Share Posted November 15, 2013 Check the mooney.com site. I saw either a sevice bulletin or service instruction that deals with this a few days ago. Has your nose gear been modified so it has no play upon landing? The additional spacer that is put in play to fix this problem can cause what you are experiencing but the other SB or SI covers how to fix this. Another thing that might help in the mean time is pressing the brakes while airborne, prior to retracting the gear. This will stop the rolling motion of the tires before they are stored, thus eliminating any rubbing noise. brakes won't help on nose wheel... 1 Quote Link to comment Share on other sites More sharing options...
scottfromiowa Posted November 15, 2013 Report Share Posted November 15, 2013 At 35psi my nose gear looks low on air...It is not. Overinflation or installation of a nose-gear-well liner and overinflation could be the problem. Get that resolved. You don't want a gear failure (GU)-landing) and go "I should have"... Quote Link to comment Share on other sites More sharing options...
isaacpr7 Posted November 15, 2013 Report Share Posted November 15, 2013 brakes won't help on nose wheel... Good catch Bob Here is the first SB that would cause the gear to touch the skin: http://www.mooney.com/images/pdfs/sb-pdf/sbm20-202.pdf I will try to find the other SB or SI that talks about the gear rubbing due to the above modification when I get a chance. Quote Link to comment Share on other sites More sharing options...
Super Dave Posted November 15, 2013 Report Share Posted November 15, 2013 Adding to the thread creep: I just listened to the Mike Busch webinar on tires, and he recommends over inflating by 10% of the POH numbers. He says that the POH numbers are assuming an unweighted tire, and a little over inflation is harmless, while under inflation is the worst thing you can do for tire life/reliability. Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted November 15, 2013 Author Report Share Posted November 15, 2013 Guys, thank you!! It seems that some bushing had to be tighten. So my AP did that and he retracted the gear and everything looked OK. So lets see when I go flying on Sunday 1 Quote Link to comment Share on other sites More sharing options...
Hank Posted November 15, 2013 Report Share Posted November 15, 2013 You folks with injected engines are too heavy. Tire pressure for a C-model is 30 psi per tire. Makes it easy to remember. Glad to hear you got it fixed! 2 Quote Link to comment Share on other sites More sharing options...
Shadrach Posted November 15, 2013 Report Share Posted November 15, 2013 There are 2 eccentrics in the gear assembly that determine the position of the nose gear when retracted. Find a good MX that is familiar with the Mooney gear and have everything checked for proper specs. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 15, 2013 Report Share Posted November 15, 2013 You folks with injected engines are too heavy. Tire pressure for a C-model is 30 psi per tire. Makes it easy to remember. Glad to hear you got it fixed! My E is 30 all around. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted November 16, 2013 Report Share Posted November 16, 2013 You folks with injected engines are too heavy. Tire pressure for a C-model is 30 psi per tire. Makes it easy to remember. Glad to hear you got it fixed! My E is 30 all around. My '75 F calls for 49 psi nose, 30 psi mains Quote Link to comment Share on other sites More sharing options...
fantom Posted November 16, 2013 Report Share Posted November 16, 2013 My '75 F calls for 49 psi nose, 30 psi mains As does my '94 J. The 231 next door to me is way different, and he's always telling me my mains look low. A genius, he ain't Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted November 17, 2013 Author Report Share Posted November 17, 2013 Guys, thank you!! It seems that some bushing had to be tighten. So my AP did that and he retracted the gear and everything looked OK. So lets see when I go flying on Sunday Indeed that was the issue. Everything looks great now. Btw I put 30 psi on the mains and 33 on the front. Quote Link to comment Share on other sites More sharing options...
scottfromiowa Posted November 17, 2013 Report Share Posted November 17, 2013 I bet mine is 30 not 35 as I stated...Mains and nose are same as Bob stated. I have a sticker on a main gear door, so I never commit to memory...My nose gear DOES look low when properly inflated. Glad you got issue resolved. Quote Link to comment Share on other sites More sharing options...
chrisk Posted November 18, 2013 Report Share Posted November 18, 2013 As does my '94 J. The 231 next door to me is way different, and he's always telling me my mains look low. A genius, he ain't I believe the mains on the 231 are 42 psi, and 49 for the nose. Quote Link to comment Share on other sites More sharing options...
SkyPilot Posted November 18, 2013 Report Share Posted November 18, 2013 That's interesting. On my J model the nose gear tire pressure specification is 49 ft. lbs. I think that the mains are either 30 or 35 ft. lbs., though. I wonder why the change between the E and the J? My counterweighted engine might be a bit heavier. Maybe that's it? Jim My F the nosewheel pressure is also 49 psi. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted November 18, 2013 Report Share Posted November 18, 2013 Just to add to the info stream... 67 F - nose gear is 49PSI, mains 30PSI. Quote Link to comment Share on other sites More sharing options...
