Glenn Posted August 23, 2013 Report Posted August 23, 2013 I am interested in any Pireps on the installation of a Lycoming IO-390 in a vintage Mooney. Quote
carusoam Posted August 23, 2013 Report Posted August 23, 2013 You should be able to find a thread on this topic already. Roller tappets should also be part of the search. Good luck, -a- Quote
KSMooniac Posted August 23, 2013 Report Posted August 23, 2013 Is that STC even eligible to go in an E/F? I suspect it needs the 201 cowl, but I'm not sure. The few reports I read were not real favorable relative to the very high cost of the conversion. Only the new Hartzell prop is STC'd to go along with that engine, so you need both and you'll likely be north of $50k all-in to complete it. 1 Quote
John Pleisse Posted August 23, 2013 Report Posted August 23, 2013 I know Henry Weber Aircraft has installed at least one, if not more. I beleive all installations are with the Top Prop. only. It's a $50k plus proposition. Contact Dorn Claire at Henry Weber. He test flew and returned the IO390's to service. He has flown Mooneys and been a MSC IA his whole life. A great resource and worth flying east if you decide to do it.. 1 Quote
orionflt Posted August 23, 2013 Report Posted August 23, 2013 There is an STC to install the 390 in the E,F and i believe J model mooney, currently you would need a field approval and cowling mod fot the C model. Quote
OR75 Posted August 23, 2013 Report Posted August 23, 2013 IMHO, a derated IO-390 could be a potential option for the IO-360 replacement and use of mogas 1 Quote
rbridges Posted August 23, 2013 Report Posted August 23, 2013 There is an STC to install the 390 in the E,F and i believe J model mooney, currently you would need a field approval and cowling mod fot the C model. I didn't know it was an option for the C model. Quote
Mooneyjet Posted August 23, 2013 Report Posted August 23, 2013 I love my "c", and it would be a mini-rocket, with the io-390, despite of the negligible weight increase of the engine, however not a upgrade option. Here is a how be available to, http://gnaircraft.com/wp-content/uploads/2011/pdfs/2011-mooney-stc.pdf Quote
orionflt Posted August 25, 2013 Report Posted August 25, 2013 I didn't know it was an option for the C model. It is not an STC option for the C model, you would have to get a field approval for the installation. There should be no issues getting a field approval based of the STC to convert the 180HP to the 200HP conversion for the "C". Quote
Mooneyjet Posted August 26, 2013 Report Posted August 26, 2013 Orionflt are you saying that perhaps, you could install the io-390 on a "c" on an around way legally. Thanks Quote
