I enjoyed watching the paper make the migration across the glare shield before I assume the vent blew it off.
Great thanks for posting. Could you give some technical details? I'd like to start filming similar to what you have done. Sweet music also. Ray
I'm still trying to figure it out myself! I use an NFlightcam+ mounted to the steel tubing above the compass. You can see the camera and accessories at http://nflightcam.com/. I use the XL Bar Mount to clamp it to the tube.
The camera generates a series of 30-minute clips (MOV files) that I copy to my computer and stitch together in QuickTime. Then I use Final Cut Pro X on the Mac to speed up the flight 20x.
You can refer to this post to learn more about the trials and tribulations I've had with my setup. Good luck!
