Selling O-360 A1D 289.93 SMOH , last annual in 3/1/2013 compressions as follows 74,73,75,70,    No damage , removed from plane w/spar corrosion...... Call Alan 856 419 5209...
Who did the annual?  When? Cylinder type and hours since surface renewal?  Are exhausts and accessories and oil lines included?  What is oil usage?
I am getting up toward 2000 hrs and might be interested.
Steve 65E NC
Annual was last month , Cerminil process on lycoming cylinders by ECI in 2006 for major overhaul , annual done by Marceco aviation, Greenville Mi,  on 3/2013 , includes carb , slick mags and harness , prop governer , vacuum pump..... Exhaust sold seperately ...
Selling IO-360 A1A 289.93 SMOH , last annual in 3/1/2013 compressions as follows 74,73,75,70,    No damage , removed from plane w/spar corrosion...... Call Alan 856 419 5209...
Alan how much do you want for it does it have the prop. Have a M20G thats coming up on TBO  Dusty
