Oil Polls
86 members have voted
  1. 1. Which oil do you primarily use?
    • Aeroshell 15W50
      14
    • Aeroshell 15W50 with Camguard
      5
    • Aeroshell W100
      8
    • Aeroshell W100 with Camguard
      5
    • Aeroshell W100 Plus
      7
    • Aeroshell W100 Plus with Camguard
      1
    • Exxon Ellite 20W50
      7
    • Exxon Ellite 20W50 with Camguard
      3
    • Phillips XC 20W50
      5
    • Phillips XC 20W50 with Camguard
      29
    • Other oil
      0
    • Other oil with Camguard
      2
  2. 2. Reason you use Camguard?
    • All the other guys use it
      6
    • I believe in it
      14
    • Published data reports
      25
    • I've used it a long time and it is doing what is supposed
      11
    • I don't use Camguard
      30
In looking at the engine logs my A/C primarily used Philips XC20W50. I began useing cam guard in the A/C but at the previous oil change to the one just done I inadvertently switched to Aero Shell 15W50 and cam guard. Now I have switched back but find that I had to add an extra quart of oil in the first 10 hrs of flight so I am thinking that the Philips might be burning a bit more oil. These first 10 hours however have included a good bit of low level training and included more take offs and landings so it might be nothing but I will keep a close eye on it. I have heard that if one changes oils you often will get differant rates of consumption.
