Does anyone know where to get the Duke’s actuator rebuilt? I have a 67 M20F?
2 hours ago, Mleahy said:
Dynamic brake not working
Can you provide more detail about the symptoms you are experiencing?  There are people here with a lot of experience with these actuators.
My ‘67 M20C had an issue where the landing gear preloads were being released by the Dukes motor.  It is supposed to prevent rotation of the motor shaft.  Mine was releasing slightly when the gear was down, and also my gear was sagging slightly when it was retracted.  It usually wasn’t enough to break contact on the up or down limit switch.  It’s not really a dynamic brake but more like a clutch that holds the motor shaft stationary.
I took it down to Ronnie at Dugosh (this was 30 years ago) and he disassembled the Dukes motor and installed two standard -10 washers, one on each post.  The problem he said was that the springs that hold that clutch stationary get weak over time.  The -10 washers are used as shims to increase the spring pressure.
Ronnie was sure to explain that this is only a temporary fix, the springs need to get replaced.  Also: these memories are 30 years old and two airplanes ago and before I got my A&P license.
Edited by Andy95W
This sounds like my problem. The gear goes up then comes back down off the switch making go up again. 2-3 times before staying up.
4 hours ago, N201MKTurbo said:
I don’t recall it having one.
I may have wrong terminology. It’s the break in the actuator. The gear comes off the up limit switch a couple of times before staying up.
I’d call Don Maxwell’s shop first and describe the problem.  They’ve been around long enough to have probably dealt with this before.  After that, I’d call LASAR.  The good news is that it’s not a huge issue.  When you send it out, you may as well have them do the work required by the Dukes gear AD and restart the clock on that as well (unless it was just done very recently.)
I have worked on motors with such a brake, I wasn’t aware that the Dukes actuator had that. It seems that it would make manual extension difficult.
I have never disassembled a Dukes motor.
It seems the ITT actuator and some of the old Dukes actuators had brakes. They have 4 wires. The newer Dukes actuators only have 2 wires.
SB-M20-189A says only the ITT has a brake.
