ighazali Posted yesterday at 09:23 AM Report Posted yesterday at 09:23 AM I am looking for headrests for my Mooney M20E, any ideas where I can buy them or would I need a seat replacement? Also the overhead Map light that has low and high setting, can someone link a LED replacement for it, looking to get a red plug and play version if possible. This is the light that is located behind right seat at the top. Any ideas on where to get a good yoke cover, I have not had any luck finding one. Thank you!
TaildraggerPilot Posted 2 hours ago Report Posted 2 hours ago Feel around the tops of those seats. I bet you will feel the tubes to insert headrest posts into. Finding actual Mooney headrests might be tough. Self-Fabrication is probably a better route. Oh, and btw, Mooney used at least two different sized tubes over the years (of course). Talk to Hector at AeroComfort in TX about yoke covers. You can swap out the map light lamp for a red LED one, but you’ll lose the “high / low” ability. I’m thinking this is for a night flying panel flood and it will do that job brilliantly. I have two above my head and they just turn on and off with no dimming. I can look for a part number when I’m at the hangar tomorrow. CB ’67 E
