For those of you who have installed a Skytec starter for the Prestolite starter on a J, what value did you use for the distance from the datum for you W&B calculation? I’m getting -24.5” and would like to compare that to others. I’ll admit to not finding the actual balance point of the starter before installing it, and I’m surely not going to remove it just to figure that out now.
TIA
Chuck
1 hour ago, N201MKTurbo said:
Is that what your tape measure says?
It’s more of a question of where to measure “from” on the starter. Since it’s rather long, it could be +/- 4” or so, depending on where the person picks to be the CG of the starter.
-24.5 is what the manual has:
Electrical Equipment
301. Alternators
(a) Alternator, 60 amp, Prestolite, ALY8420, ALY8403, ALY6420 or ALY8420M (S/N 24-0001 thru 24-2999)  10.3 lbs. -24.5
(b) Alternator, 70 amp, Prestolite, ALU6421-LS (S/N 24-3000 and on) 10.3 lbs. -24.5
Edited by Paul Thomas
301. Alternators
Even a blind squirrel finds a nut every now and then. What manual is this from?
Thanks!
Edited by RoundTwo
I thought the question was about the starter? That document is the FAA TCDS (Type certificate data sheet).
It lists the original prestoline/prestolite starter as Flight Station (F.S.) -23.0
Yes, my initial excitement was quelled after I looked more closely and saw it only had alternator.
Edited by RoundTwo
You're correct, I'm not sure why I provided info for the alternators.
You should check the equipment list in your POH in the weight and balance section. it’s much more thorough than the TCDS.
