FlyingDude Posted June 6, 2025 Report Posted June 6, 2025 Hello all, The service manual doesn't cover this topic. How can the bolts be backed out to replace the aft pucks as well? Other than disconnecting the engine mounts from the firewall or drilling a hole in the firewall. Thanks
N201MKTurbo Posted June 6, 2025 Report Posted June 6, 2025 You have to remove the engine mount from the firewall. You can just tilt it down, but it gets weird when you remove the motor mounts. 1 1
N201MKTurbo Posted June 6, 2025 Report Posted June 6, 2025 Or, you just beat dents into the footwells like someone did to my plane before I got it. 1 1
201Steve Posted June 8, 2025 Report Posted June 8, 2025 On 6/6/2025 at 5:21 PM, N201MKTurbo said: Or, you just beat dents into the footwells like someone did to my plane before I got it. My airplane made it nearly 50 years without getting dented. Jewel Aviation (Kennett MO) was sure to ruin it. They said “oh they are all like that, it’s easy to fix, you just beat it back from the other side”. 3
