Healthpilot Posted January 31, 2025 Report Posted January 31, 2025 I connected the Battery Minder cigarette lighter adapter to the cigarette lighter plug in the cockpit and now the USB adapter (tried 3 different ones) is not working. Is there a circuit breaker that I don't see on the panel for this one?
Ragsf15e Posted January 31, 2025 Report Posted January 31, 2025 4 minutes ago, Healthpilot said: I connected the Battery Minder cigarette lighter adapter to the cigarette lighter plug in the cockpit and now the USB adapter (tried 3 different ones) is not working. Is there a circuit breaker that I don't see on the panel for this one? Fuse?
M20S Driver Posted January 31, 2025 Report Posted January 31, 2025 Mine also has an inline fuse and a circuit breaker. Trace the wire and you will see it if yours has it too.
Fly Boomer Posted January 31, 2025 Report Posted January 31, 2025 1 hour ago, Healthpilot said: I connected the Battery Minder cigarette lighter adapter to the cigarette lighter plug in the cockpit and now the USB adapter (tried 3 different ones) is not working. Is there a circuit breaker that I don't see on the panel for this one? Is this how you plan to keep your battery topped off? It would certainly eliminate all the wiring that many install back to the avionics bay.
Schllc Posted January 31, 2025 Report Posted January 31, 2025 Installing the cables for the batteries is about as easy as it gets. you can run the dongles to the tks door, or the hat rack with a grommet. the parts usually come with the chargers and takes less than two hours to install everything. the gauge of wire to the cigarette lighter is pretty small, I would be very suspect of the efficacy of that method, or the safety. 1
Fly Boomer Posted January 31, 2025 Report Posted January 31, 2025 2 minutes ago, Schllc said: the gauge of wire to the cigarette lighter is pretty small, I would be very suspect of the efficacy of that method, or the safety. Well, a dedicated line to the battery or batteries would be best, but I would have guessed that the wiring to the cigar lighter would be fairly robust. But, I have never paid attention to it before.
Schllc Posted February 1, 2025 Report Posted February 1, 2025 Your batteries are directly beneath the hatrack and very easily accessible. get a stool and prepare to contort and scrape some knuckle but it’s very straightforward. The charger lines come with an inline fuse and both ends are finished to fit battery lugs and charger cord. the battery minder seems to work well for me. 1
atpdave Posted February 1, 2025 Report Posted February 1, 2025 1 hour ago, Healthpilot said: I connected the Battery Minder cigarette lighter adapter to the cigarette lighter plug in the cockpit and now the USB adapter (tried 3 different ones) is not working. Is there a circuit breaker that I don't see on the panel for this one? The cigarette lighter socket in your plane (SN 29-0464) is connected with a 16GA wire to a voltage converter (output voltage 13.7-13.9VDC 5A) mounted on the tailcone bulkhead. The 5A inline fuse for the converter is attached to battery relay 2. It should have a label (if it hasn't fallen off) that says VOLT CONV or something like that. If the fuse isn't blown then the converter is probably fried. The good news is they can be found online for cheap, even on eBay. Search for Transelectric SM2412-5. I think these things were used on golf carts. 1
Fritz1 Posted February 1, 2025 Report Posted February 1, 2025 As stated before your cigarette lighter may be 12V, you have two 24V batteries, not sure if you can backfeed though the step down transformer, standard solution is an Anderson connector on each battery, if no tks door, Anderson connectors are typically mounted on hat rack or on left cabin panel in luggage compartment, think battery minder sells Anderson connector kit with fuse 1
Healthpilot Posted February 3, 2025 Author Report Posted February 3, 2025 On 2/1/2025 at 6:06 AM, Fritz1 said: As stated before your cigarette lighter may be 12V, you have two 24V batteries, not sure if you can backfeed though the step down transformer, standard solution is an Anderson connector on each battery, if no tks door, Anderson connectors are typically mounted on hat rack or on left cabin panel in luggage compartment, think battery minder sells Anderson connector kit with fuse Correction: The cigarette lighter sock has a label 14V 3 AMPS MAX 5 A Intermittent.
Healthpilot Posted February 3, 2025 Author Report Posted February 3, 2025 On 1/31/2025 at 4:34 PM, atpdave said: The cigarette lighter socket in your plane (SN 29-0464) is connected with a 16GA wire to a voltage converter (output voltage 13.7-13.9VDC 5A) mounted on the tailcone bulkhead. The 5A inline fuse for the converter is attached to battery relay 2. It should have a label (if it hasn't fallen off) that says VOLT CONV or something like that. If the fuse isn't blown then the converter is probably fried. The good news is they can be found online for cheap, even on eBay. Search for Transelectric SM2412-5. I think these things were used on golf carts. Thank you, Dave I will check, and report back.
Healthpilot Posted February 3, 2025 Author Report Posted February 3, 2025 On 1/31/2025 at 3:32 PM, Fly Boomer said: Is this how you plan to keep your battery topped off? It would certainly eliminate all the wiring that many install back to the avionics bay. I was not planning to charge the battery this way but rather just update G1000 databases and learn buttonology without depleting batteries. 1
