mooneyflyer Posted December 24, 2024 Report Posted December 24, 2024 For years I thought one cannot slip a long body with full flaps. But somebody challenged they and now I can’t find anything on this. Does anyone know about this? Could not find in my POH
dzeleski Posted December 24, 2024 Report Posted December 24, 2024 (edited) 15 minutes ago, mooneyflyer said: For years I thought one cannot slip a long body with full flaps. But somebody challenged they and now I can’t find anything on this. Does anyone know about this? Could not find in my POH There are a few chats about this but this was a popular one. This one is also good Edited December 24, 2024 by dzeleski
Brandt Posted December 25, 2024 Report Posted December 25, 2024 There is no restriction in the M20V POH. I have done so many times. No issue.
PT20J Posted December 25, 2024 Report Posted December 25, 2024 Good article in Mooney Flyer by Bob Kromer https://themooneyflyer.com/issues/2019-AprTMF.pdf 3
M20F-1968 Posted December 26, 2024 Report Posted December 26, 2024 On 12/24/2024 at 6:22 PM, mooneyflyer said: For years I thought one cannot slip a long body with full flaps. But somebody challenged they and now I can’t find anything on this. Does anyone know about this? Could not find in my POH Rather than slipping to loose altitude or slow down, put out the speed brakes. I have speed brakes in my F (highly modified) and some of my best landings were done with full flaps and speed brakes. The plane flies just as well, you need to carry more power, it feel heavier (since I believe wing loading is increased) but you use the same numbers. Works well in a crosswind as it allows you to use more power. I have done one go-around in this configuration as well, getting rid of the speed brakes first as there is no altitude loss in doing so. John Breda 1
hubcap Posted December 26, 2024 Report Posted December 26, 2024 On 12/25/2024 at 10:26 AM, PT20J said: Good article in Mooney Flyer by Bob Kromer https://themooneyflyer.com/issues/2019-AprTMF.pdf Bob has spoken about this issue at Mooney Max. I have followed his advice on the issue as I believe him.
Danb Posted December 26, 2024 Report Posted December 26, 2024 7 hours ago, M20F-1968 said: Rather than slipping to loose altitude or slow down, put out the speed brakes. I have speed brakes in my F (highly modified) and some of my best landings were done with full flaps and speed brakes. The plane flies just as well, you need to carry more power, it feel heavier (since I believe wing loading is increased) but you use the same numbers. Works well in a crosswind as it allows you to use more power. I have done one go-around in this configuration as well, getting rid of the speed brakes first as there is no altitude loss in doing so. John Breda John I’ve never landed with speed brakes on there disengaged after dropping landing gear, what do you do differently when landing with them on and what should be expected vs landing without TY D
Brandt Posted December 26, 2024 Report Posted December 26, 2024 7 minutes ago, Danb said: John I’ve never landed with speed brakes on there disengaged after dropping landing gear, what do you do differently when landing with them on and what should be expected vs landing without TY D Speed brakes have no impact on landing attitude or stall speed and they become less effective as you slow down to short final speeds so their impact on Sink rate become less as you slow. Landing with them extended is a non-event. 1
M20F-1968 Posted December 29, 2024 Report Posted December 29, 2024 On 12/26/2024 at 3:48 PM, Danb said: John I’ve never landed with speed brakes on there disengaged after dropping landing gear, what do you do differently when landing with them on and what should be expected vs landing without TY D You do nothing differently. Fly your approach by the same numbers you would otherwise. You will need to carry more power to keep the same numbers (airspeed) and the plane feels heavier, but that is a good thing. In a crosswind the plane is more stable given that you are carrying more power. Some of my best landings have been when I extended speed brakes, forgot they were out, landed and realized they were still out on the ground. My mechanic (high time very experienced Mooney person) does all (or nearly all) landings in the Ovations and Acclaims he flies with speed brakes out. On a go around the plane will climb but realize the configuration you are in and do not be aggressinve. Keep the nose lower than you might without speed brakes out, retract the speed brakes as they are quick to retract, then raise gear, then flaps. John Breda
