LANCECASPER Posted Tuesday at 04:22 AM Report Posted Tuesday at 04:22 AM On 11/17/2024 at 7:55 PM, 1980Mooney said: So then it would seem that the newer Mooney's with non-WAAS G1000 without an upgrade path to NXi are also on borrowed time. Every other aircraft manufacturer that installed the G1000 over the past 20 years, as far as I know, now have an upgrade path to NXi. American General AAG5 Tigers with G1000s and Columbia 400s with G1000s never even made it to WAAS upgrades, let alone NXi upgrades/ Quote
Will.iam Posted Tuesday at 02:12 PM Report Posted Tuesday at 02:12 PM On 11/17/2024 at 12:06 PM, kortopates said: I’ve always been able to get a new PC to run old s/w like that using compatibility mode. You can experiment with different setting but going straight to XP service pack 3 should work perfectly for this. Sent from my iPhone using Tapatalk I use a current windows 11 computer to cut my cards. Have not had an issue until i got a spare nav card as i wanted to be able to cut a card for the next database cycle and thus just swap the cards when i was out at the plane the next time. I then tried to cut the other card as a spare as a backup. But garmin database manager will fail when you try that. You can swap cards every new cycle but can not have 2 cards on same cycle so as to keep people from sharing a subscription as the old gns units do not check for a subscription code where as the newer units do. Quote
1980Mooney Posted Tuesday at 04:03 PM Report Posted Tuesday at 04:03 PM 10 hours ago, LANCECASPER said: American General AAG5 Tigers with G1000s and Columbia 400s with G1000s never even made it to WAAS upgrades, let alone NXi upgrades/ You are correct. Both Tiger Aircraft LLC and Columbia Aircraft went bankrupt in 2007. As far as I can tell Tiger Aircraft only built four (4) AG5B with G1000 during 2005-2006 before ceasing production. An unknow number of Columbia 400's were built in 2006-2007 with the G1000 before bankruptcy. Some show up for sale with WAAS upgrade. After Cessna acquired the design & assets, the 2008 "Cessna 400" models came standard with G1000 WAAS. Quote
