Can anyone confirm that the inflatable door seal was standard on all m20k 231's. My son and I are shopping and we've been told that door will leak if parked outside so you have to have a cover for it.  Can the inflateable seal be replaced at a reasonable cost with a regular door seal?
Inflatable door seals have never been installed by Mooney, or have ever been standard equipment.
The Bob Fields Inflatable Door Seal is installed through an STC:  https://aerocessories.aero/
A search of Mooneyspace shows a lot of information on this subject:
https://mooneyspace.com/search/?q="Bob Fields"&quick=1&updated_after=any&sortby=relevancy
Thanks for that info.  I did search "door seal" and got no hits, so that's why I added the new topic.  Brand new to this forum.  Will learn my way around.  Thanks
I just replaced the door seal on my 231 with a new non-inflatable seal.  It was previously a non-inflatable as well, but very old.    I doubt the new one will leak any time soon.  But there are many possible points for water to get inside the cabin and if you have to leave it outside I would recommend a cover regardless of what door seal you have.
My door seal was < $250 even including stripper for the old seal and new adhesive.   This is trivially cheap in the airplane world.  :)   The labor though...  Whew!   I spent probably 15 or 20 hours on this project.
Some door seal threads:
I find using google for search “door seal site:mooneyspace.com” more helpful than the MS integrated search.
